1MileCrash
- 1,342
- 41
I have a few questions about proving that a set is a vector space.
1.) My book lists 8 defining properties of a vector space. I won't list them because I'm under the impression that these are built into the definition of a vector space and thus are common knowledge.
My book also says that all vector spaces have the property that any linear combination of elements is also an element.
My question is this: In showing something is a vector space, do I need to show that the former 8 properties hold, that the linear combo idea holds, or both?
I've seen discussions online where people show only that linear combinations are members of the set, so the set is a vector space. Does this guarantee that those 8 properties hold, or are they just speaking of some specific example (like a subspace of a known vector spaces, where many of those 8 properties are "grandfathered in")?
2.) If the elements of the set are said to be "real valued" can I just use the field axioms of the reals to show that these 8 properties will hold?
For example, I was asked to show that the set of all differentiable real-valued functions is a vector space.
Is it sufficient to show that any linear combination of differentiable functions is differentiable (through properties such as constants being pulled from the differentiation operator, and that the derivative of a sum is a sum of derivatives) and real valued, and then use the field axioms of the set of reals to show the other 8 properties?
Thank you
Thank you
