A few questions about the Einstein field equations?
In summary: There are many complex mathematical concepts in GR that are used to make predictions about the universe. It can be difficult for the average person to fully understand these concepts without having a good foundation in mathematics.
zeromodz
246
1) What exactly does the metric tensor expand into? Since it describes general space-time, shouldn't it be more like a vector like
R = √(x^2+y^2+z^2)
Why even should we use tensors in relativity when we can just stick with vectors?
2) Are the equations all theoretical? Have they been proven? Can they calculate anything physical calculations like exactly to what angle or degree space and time are curved?
3) Why do all the equations and math attempt to look so confusing? I have been doing a lot of research on the equations recently, and I am deducing that theoretical physicists use redundant notations just to make everything seem too complex for an average person to understand?
Thank you!
1) GR deals with curved 4-dimensional psuedo-riemannian manifolds. Do some reading on those, then see if you can avoid using tensor quantities when expressing genereal expressions.
2) Einstein's equation can be used to calculate extremely accurately any orbit, as well as gives very accurate predictions of time dilations. Read about how a GPS system works. It uses GR to function properly.
R = √(x^2+y^2+z^2)
In simple terms, a metric generalizes the dot product of two vectors to the case where space(time) is curved. If [tex]\vec{r} = (x,y,z)[/tex], then
[tex]|\vec{r}| = \sqrt{ g_{ij} r^i r^j}.[/tex]
In flat space where [tex] g_{ij} = \delta_{ij}[/tex], this reduces to the formula that you quoted.
Einstein's equations have been proven to be valid in many situations. Perhaps the most down to Earth application is to the GPS system. General relativity is required to obtain correct positions from the satellite references.
Examples? Scientific notation is generally chosen to make it easier for scientists to do calculations, not to make it easier for lay people to understand.
Related to A few questions about the Einstein field equations?
1. What are the Einstein field equations?
The Einstein field equations are a set of ten equations in Albert Einstein's theory of general relativity that describe the relationship between the curvature of spacetime and the distribution of matter and energy within it.
2. What is the significance of the Einstein field equations?
The Einstein field equations are significant because they provide a mathematical framework for understanding the behavior of gravity and its effects on the universe. They have been proven to accurately describe the large-scale structure of the universe, including the motion of planets, stars, and galaxies.
3. How were the Einstein field equations derived?
The Einstein field equations were derived using mathematical principles of differential geometry and tensor calculus. Albert Einstein spent over ten years developing and refining these equations, which were first published in 1915.
4. Can the Einstein field equations be applied to all situations?
No, the Einstein field equations are only applicable to situations where the effects of gravity are significant and cannot be ignored. They do not apply to the microscopic world of quantum mechanics, where other theories, such as the standard model, are used to describe the behavior of particles.
5. Have the Einstein field equations been proven to be correct?
Yes, the predictions made by the Einstein field equations have been confirmed by numerous experiments and observations. However, they are not considered a complete theory of gravity and are still being tested and refined by scientists.
