MHB A finite number of positive integer solutions 1/x+1/y=p/q
The equation 1/x + 1/y = p/q has been analyzed, demonstrating that for a given rational number p/q, there exists only a finite number of positive integer solutions. The discussion highlights the mathematical reasoning behind this conclusion, focusing on the constraints imposed by the rational nature of p/q. Participants engage in providing insights and solutions, with kaliprasad contributing a notable solution. The finite nature of the solutions is attributed to the properties of rational numbers and their relationship with integer values. Overall, the discussion emphasizes the limited scope of solutions in this mathematical context.
lfdahl
MHB
Given a rational number, $\frac{p}{q}$, show that there are only a finite number of positive integer solutions to the equation:
$$\frac{1}{x}+\frac{1}{y}=\frac{p}{q}$$
Mathematics news on Phys.org
without loss of generality we can assume x <= y so $\frac{1}{x} >=\frac{1}{y}$ Even if we require ordered pair number number of solutions cannot be > double of the case x <= y
further there exists n such that $\frac{1}{n+1} < \frac{p}{q} < \frac{1}{n}$ so $\frac{1}{x} > \frac{1}{2n}$
there are a finite values x < 2n and x >n) that satisfy the criteria hence finite solutions ( I have provided the estimates with +/- 1 and not exact bound)
Hi, kaliprasad!
Thankyou very much for your solution! Please explain how you conclude, that: $\frac{1}{x} >\frac{1}{2n}.$
lfdahl said:
Hi, kaliprasad!
$\frac{1}{x} + \frac{1}{y} = \frac{1}{n}$
if ( a + b = 2c) and a > b then a > c else a + b < c + c or a +b < 2c
based on above $\frac{1}{x} >\frac{1}{2n}$
Thankyou very much, kaliprasad for your participation and a nice solution!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
