A Force Changing With Distance (bead moving on a curved wire)
In summary, there is a problem involving an equation that requires the utilization of energy and a changing acceleration. The equation for energy conservation is also mentioned, as well as a force that linearly increases with time. However, there are some clarifications needed, such as a diagram, the shape of the curved wire, and the initial velocity. Additionally, it is stated that the only force acting on the system is gravity, but this seems to contradict the description of a force increasing linearly with distance. Further clarification is needed before a solution can be provided.
gkg
A bead moving along a curved wire is acted upon by a downwards force that increases linearly with distance from the initial x-position. The bead arrives at the end of the wire a distance of L from its initial position in t amount of time. Derive an expression to find the final velocity of the bead. Assume that the wire is frictionless and the only force acting upon the system is gravity.
v(f) = v(0) + a*t
I initially tried to solve this equation using work, but was stuck in a confusing integral that didn't make sense. I am almost sure that the utilization of energy is needed to solve this equation, but I have been flustered for the past three days at solving this.
That formula you wrote assumes constant acceleration.
Why not post what your actual attempt was, i.e. that integral you mentioned.
How would energy conservation equation look like? Post it and I can give you a hint how to proceed
Likes MatinSAR
With a changing acceleration that equation would be:
v(f) = v(0) + (da/dt) t^2
Assuming a force that linearly increases with time, the work equation would be:
W = Integral(m*a*x) dl, where max is the force equation and dl is the line integral.
Since energy is not actually conserved and it seems to be increasing due to the increasing force the energy equation would be:
1/2*m*v(f)^2 + U(f) = U(0) +1/2*m*v(0)^2
Where U stands for the potential energy, as the bead does go up in the y-direction from the curve of the wire that it is on.
You can see for yourself if this is not correct. Hint, change in v is the integral of a.
Do you know of a real force that grows with distance? Learned about Hookes law? Isnt such force conservative?
Likes MatinSAR
How did ##\int a\cdot dt## become ##da/dt\cdot t^2##?
On what basis? You are told it increases linearly with distance.
Likes MatinSAR
Hi @gkg and welcome to PF.
In addition to the other replies, please note that are some problems with the question.
Is the question complete? The issues that spring to mind are:
- Is there a diagram?
- Is the shape (or at least the positions of the start and end points) of the curved wire defined ?
- Is the initial velocity (or maybe that should be speed) zero? Or some given quantity?
- The question asks for the final velocity; this would require a direction as well as a magnitude – should the question be asking for final speed?
Also, you may find it helpful to read the ‘rules’ so you know what to expect here! https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
Likes MatinSAR
If the only force is gravity, what is the point of describing that force which increases linearly with distance? How is this force relevant to the problem? Or is gravity supposed to be this force increasing linearly with distance? The problem needs clarification before asking for a solution. And what Steve4Physics wrote, too.
Likes malawi_glenn and MatinSAR
nasu said:
If the only force is gravity, what is the point of describing that force which increases linearly with distance? How is tReplyhis force relevant to the problem?
In fact the question says "... the only force acting upon the system [my underlining] is gravity.".
Assuming that's a correct staement, it implies the system is in free-fall. That's probably not the intention!
We await clarification from @gkg.
Likes nasu
FAQ: A Force Changing With Distance (bead moving on a curved wire)
What is the physical principle behind a bead moving on a curved wire?
The motion of a bead on a curved wire is governed by the principles of classical mechanics, specifically Newton's laws of motion. The bead experiences a normal force from the wire and gravitational force, and its motion is constrained to follow the curvature of the wire. The net force acting on the bead can be decomposed into components along the wire (tangential) and perpendicular to the wire (normal).
How does the curvature of the wire affect the motion of the bead?
The curvature of the wire affects the normal force acting on the bead and, consequently, its acceleration. In regions where the wire curves more sharply, the bead experiences a greater centripetal force, which can alter its speed and direction. The bead's velocity and acceleration are influenced by the wire's shape, leading to complex motion that depends on the specific curvature.
What role does friction play in the motion of the bead on the wire?
Friction between the bead and the wire can significantly impact the bead's motion. If friction is present, it will oppose the bead's motion, causing it to lose kinetic energy and potentially come to a stop. In an idealized scenario with no friction, the bead would continue to move indefinitely along the wire, solely influenced by gravitational and normal forces.
How can we mathematically describe the motion of the bead on a curved wire?
The motion of the bead can be described using differential equations derived from Newton's second law. These equations take into account the forces acting on the bead, including gravity, normal force, and any frictional forces. The wire's curvature can be expressed as a function of position, and the resulting equations can be solved to determine the bead's trajectory, velocity, and acceleration as functions of time.
What are some practical applications of studying a bead moving on a curved wire?
Understanding the motion of a bead on a curved wire has applications in various fields, such as mechanical engineering, robotics, and biomechanics. For instance, it can help in designing roller coasters, understanding the dynamics of particles in curved tracks, or analyzing the movement of biological molecules along curved pathways. These principles can also be applied to optimize the design of transportation systems and amusement park rides.
