A Fraunhofer diffraction pattern is produce on a screen
In summary: Therefore, in summary, the slit width is equal to 2.18 m divided by 58064400 times the wavelength (lambda).
AnnieMoo
A Fraunhofer diffraction pattern is produced on a screen 218 cm from a single slit. The distance from the center of the central maximum to the first-order maximum is 7620 times the wavelength (lambda). Calculate the slit width. Answer in __m
I have no idea how to even start this problem but this is what I tried.
7620 = (1.5 * 2.18)/a where a is the slit width.
This was not correct. I would really appreciate any kind of help on this!
Hello, thank you for posting your problem. I can help guide you through solving this problem.
The first thing we need to do is understand the Fraunhofer diffraction pattern and what it tells us. The Fraunhofer diffraction pattern is formed when a single slit is illuminated with a coherent light source, such as a laser. It produces a pattern of bright and dark fringes on a screen placed at a certain distance from the slit.
In this problem, we are given the distance from the screen to the slit (218 cm) and the distance from the central maximum to the first-order maximum (7620 times the wavelength). We also know that the distance between adjacent bright fringes is equal to the wavelength (lambda).
Now, let's think about what the distance between the central maximum and the first-order maximum represents. Since we know that the distance between adjacent bright fringes is equal to the wavelength, and the first-order maximum is 7620 times the wavelength away from the central maximum, this means that there are 7620 bright fringes between the central maximum and the first-order maximum.
So, we can set up an equation using this information:
7620 * lambda = distance between central maximum and first-order maximum
lambda = distance between adjacent bright fringes
Now, we can rearrange this equation to solve for the wavelength:
wavelength = (distance between central maximum and first-order maximum) / 7620
We know that the wavelength is equal to the slit width (a) times the distance between adjacent bright fringes, so we can set up another equation:
wavelength = a * (distance between adjacent bright fringes)
Now, we can combine these two equations and solve for the slit width (a):
a = (distance between central maximum and first-order maximum) / (7620 * distance between adjacent bright fringes)
Plugging in the values we were given, we get:
a = (218 cm) / (7620 * lambda)
Now, we need to convert the given distance in centimeters to meters, and we know that 1 m = 100 cm, so:
a = (2.18 m) / (7620 * lambda)
Finally, we can substitute the given value for the distance between the central maximum and first-order maximum (7620 * lambda) into this equation:
a = (2.18 m) / (7620 * 7620 * lambda)
We can simplify this to:
Related to A Fraunhofer diffraction pattern is produce on a screen
1. What is a Fraunhofer diffraction pattern?
A Fraunhofer diffraction pattern is a pattern of bright and dark bands that is produced when a coherent light source passes through a small aperture or slit and is then observed on a screen. It is named after German physicist Joseph von Fraunhofer who first described this phenomenon in the early 19th century.
2. How is a Fraunhofer diffraction pattern produced on a screen?
A Fraunhofer diffraction pattern is produced when a coherent light source, such as a laser, passes through a small aperture or slit. The light waves diffract, or spread out, as they pass through the aperture and interfere with each other, creating the pattern on a screen placed behind the aperture.
3. What factors affect the appearance of a Fraunhofer diffraction pattern?
The appearance of a Fraunhofer diffraction pattern is affected by several factors, including the size and shape of the aperture or slit, the wavelength of the light used, and the distance between the aperture and the screen. These factors can alter the spacing and intensity of the bands in the pattern.
4. What is the significance of a Fraunhofer diffraction pattern in scientific research?
A Fraunhofer diffraction pattern is important in scientific research as it provides valuable information about the properties of light and the behavior of waves. It is commonly used in fields such as optics, astronomy, and material science to study the diffraction of light and to analyze the structure of materials.
5. Can a Fraunhofer diffraction pattern be used to determine the size of an aperture or slit?
Yes, a Fraunhofer diffraction pattern can be used to determine the size of an aperture or slit. By measuring the distance between the bands in the pattern, the size of the aperture can be calculated using the principles of diffraction. This is known as Fraunhofer diffraction analysis and is a commonly used technique in optics and engineering.
