A Function domain/range question
  • Thread starter L Huyghe
  • Tags
    Function
In summary, the conversation discusses the concept of a function with a domain of (0,1) and a range of [0,1]. The participants explore different approaches and examples to try and find a function that fits these conditions. Ultimately, they conclude that while there is no continuous, invertible function that maps (0,1) to [0,1], there are ways to construct a function that can map a subset of (0,1) to [0,1). However, this may require breaking the problem into smaller, more manageable pieces.
L Huyghe
Give an example of a function whose domain equals the interval (0,1) but whose range is equal to [0, 1].
2. The attempt at a solution
I can't see a way how such function would exits. I though about it this way, if it was the opposite Domain [0,1] and range (0, 1), we could make values 0 and 1 into any number in between without it not being a function, and still having a range that is an interval. If I take domain (0, 1) and produce range [0, 1], I would need to take one of the numbers from (0, 1) and make it [0, 1]. Meaning its no longer has an range that is an interval. It could have a range that is an interval if one of numbers (0, 1) had two possible answers, but the example would no longer be a function.
You don't have to have an equal-measure correspondence between your domain and range.
Try mapping the domain (0,1/2) to the range (0,1). You can do it, right? Now extend the domain to (0,1) and use the endpoints too.
There is no continuous function that will do map (0, 1) to [0, 1]. I frankly don't see any way to construct a function to fit these conditions that would make sense in a precalculus class. I would separate (0, 1) into rational and irrational numbers, map the irrational numbers to themselves, the "shift" the rationals to fit 0 and 1 in.
There is no continuous, invertible function that maps (0,1) to [0,1]. However, there is no continuous function that maps [0,1] to (0,1).
The problem is, IMO, rather easy as soon as you get past the mental blocks -- e.g. limiting your thought to invertible functions, avoiding piecewise-defined functions, trying to do the whole problem in one shot rather than breaking it into easier pieces, et cetera.
Consider the function y=x2. It maps the open interval (-1,1) to the half-closed interval [0,1). If you understand how the half-closure comes about in this case, you should be able to figure out a suitable function for your problem.
FAQ: A Function domain/range question
What is a function domain?
A function domain is the set of all possible input values for a function. It represents the independent variable in a function and determines the range of the function.
How do you find the domain of a function?
To find the domain of a function, you need to look at the restrictions on the input values. Common restrictions include division by zero, square root of a negative number, and logarithm of a non-positive number. You should also consider any given domain restrictions in the function's definition.
3. What is a function range?
A function range is the set of all possible output values for a function. It represents the dependent variable in a function and is determined by the domain of the function.
4. How do you determine the range of a function?
To determine the range of a function, you need to look at all the possible output values that can be obtained from the given input values. This can be done by graphing the function or using algebraic methods such as substitution and solving for the output variable.
5. What is the difference between the domain and range of a function?
The domain and range of a function are two different sets of values. The domain is the set of all possible input values for the function, while the range is the set of all possible output values. In other words, the domain represents the independent variable, and the range represents the dependent variable in a function.
