friend
- 1,452
- 9
I'm trying to generalize the property of the Kronecker delta function which gives
[tex]\sum\nolimits_{i = 0}^n {{\delta _{ij}}} = \left\{ {\begin{array}{*{20}{c}}
1&{0 < j < n\,\,\,\,\,\,\,\,\,\,\,}\\
0&{j < 0\,\,or\,\,n < j}
\end{array}} \right\}\,\,.[/tex]
The continuous case seems to be the Dirac delta function such that
[tex]\int_R {{\rm{\delta (x - }}{{\rm{x}}_0}){\rm{dx}}} = \left\{ {\begin{array}{*{20}{c}}
1&{{x_0} \in R}
\end{array}}\\
0&{{x_0} \notin R}
\end{array}}
But only using the Dirac delta function seems too restrictive for most applications. I'd like to keep the property of the integral being either 0 or 1, depending on whether some parameter, x0, is or is not within the limits of the integral. But I can't think of any other function for which this is true. It seems that any other continuous function defined only in R will give the same integral no matter if x0 is inside or outside R. So it seems the only way to insure that x0 is always within R is to make R be the whole real line from -∞ to +∞, in which case there is no integration to 0 since x0 is always within R.
But I'm sure I don't know everything. And someone here might know something I don't.
1&{{x_0} \in R}
\end{array}}\\
0&{{x_0} \notin R}
\end{array}}
