A gaseous mixture contains ethane and propane problem
In summary, the conversation is about calculating the mass percent of ethane in a gaseous mixture containing ethane and propane, given the complete combustion of the mixture to form carbon dioxide and water. The approach involves solving two equations, but the results obtained are sensitive to errors and vary depending on the molar masses used. The solution manual disagrees with the calculated result and it is suggested that changing the unknown to either the amount of ethane or propane may provide a clearer understanding.
skepticwulf
74
A 9.780-g gaseous mixture contains ethane (C2H6) and propane
(C3H8). Complete combustion to form carbon dioxide
and water requires 1.120 mole of oxygen gas. Calculate the
mass percent of ethane in the original mixture.
7/2 mol O2 burns 1 mole ethane, then x mole O2 burns 2x/7 mole ethane (A)
5 mole O2 burns 1 mole propane, then (1.12-x) mole O2 burns (1.12-x)/5 mole propane (B)
Multiplying A and B with ethane's and propane's molar masses and adding them will give 9,78g.
So solving that for x and then recalculating A for ethane and finally then dividing by 9.78 should give mass percent of ethane.
But, this solution disagrees with solution manual, mine is %29,14, textbook's %38.
I do understand the solution(there's a solution besides an answer) of textbook but I do not understand why mine is incorrect!
Show your math, description is just hard to follow.
Generally speaking it is an example of a problem in which the final result is extremely sensitive to errors (so called ill-conditioned set of equations). My approach to the solution called for solving two equations. Depending on molar masses used I got very different results:
http://www.wolframalpha.com/input/?i=solve+44.09562*y+30.06904*x=9.78+and+7/2*x+5*y=1.12+for+x,+y
http://www.wolframalpha.com/input/?i=solve+44*y+30*x=9.78+and+7/2*x+5*y=1.12+for+x,+y
(click on "approximate form" to see the decimal result).
Note the plot - it contains two lines, each representing one of the equations. They are almost parallel, which means shifting one of them by a minute amount (which is what I did by using more precise molar mass) results in a huge difference in the final result.
Actually it is not surprising the lines are parallel, when "normalized" these equations look like
3.07x + 4.50y = 1
3.13x + 4.46y = 1
Do you see how similar they are?
I use my blackboard for solutions so I had to take a picture of all, hope you will read my writing :)
I still don't understand why you expect me to spend time guessing what your x is, instead of explaining it so that I don't have to waste time.
It is number of moles of oxygen that reacted with ethane, right?
Your equation looks OK, what I wrote still holds. Put more precise molar masses into the equation in the upper right corner and you will end with substantially different result.
Sorry, I thought it was pretty obvious :)
Yes, it is the number of moles of O2.
Thank you for the help.
It is not quite a natural choice of a single unknown. I would go for amount of ethane or amount of propane (after all, that's what you want to find). Not that the choice of unknown invalidates your approach, it just makes it more difficult to analyze.
Related to A gaseous mixture contains ethane and propane problem
1. What is a gaseous mixture?
A gaseous mixture is a combination of two or more gases that are physically mixed together and do not chemically react with each other.
2. What is ethane and propane?
Ethane and propane are both hydrocarbon gases, meaning they are made up of carbon and hydrogen atoms. They are commonly used as fuels and are found in natural gas and petroleum.
3. How do you determine the composition of a gaseous mixture?
The composition of a gaseous mixture can be determined by various methods such as gas chromatography, mass spectrometry, and gas density measurements.
4. What is the purpose of solving a problem involving a gaseous mixture containing ethane and propane?
The purpose of solving a problem involving a gaseous mixture containing ethane and propane is to determine the amount or concentration of each gas present in the mixture, which can be useful in various industrial and environmental applications.
5. How can the properties of ethane and propane affect the behavior of a gaseous mixture?
The properties of ethane and propane, such as boiling point and vapor pressure, can affect the overall behavior of a gaseous mixture, such as its stability and flammability. These properties can also impact the efficiency of various processes that involve the use of the mixture.
