A gear that i don't know its name
  • Thread starter cyth0987
  • Tags
    Gear
In summary, the conversation discusses the double slit experiment and the possibility of using a weak light source to send photons one by one. The experiment was first performed in 1909 with light, and in 1961 with electrons. It was voted the most beautiful experiment in 2002. The conversation also brings up questions about using different screens for the experiment and how to decrease photon density to a single photon.
cyth0987
everyone know double slit experiment. my question is about second experi which chanced physics. how do we send photons one by one. which machine is used for that and can i get it from somewhere thanks for your answers
A very weak source of light will do that!
I wonder if two polarizers placed nearly 90 degrees apart would reduce a light source to nearly single photons?
okay we never know a weak source disseminate how much photon and i think it disseminates millions of it. i am waiting for another answers
Uhh, what?
The source could be turned down low enough so the emmision is practically single photons.As they say in Wikipedia,
A low-intensity double-slit experiment was first performed by G. Taylor in 1909,[6] by reducing the level of incident light until photon emission/absorption events were mostly nonoverlapping. A double-slit experiment was not performed with anything other than light until 1961, when Clauss Jönsson of the University of Tübingen performed it with electrons.[7][8] In 2002, Jönsson's double-slit experiment was voted "the most beautiful experiment" by readers of Physics World.[9]
http://en.wikipedia.org/wiki/Double-slit_experiment
okay with your answers and with a few site, I've realized that experi had performed with a very weak source so we have another questions now.
1- can i use every screen for this exp. my cellphone, my telly etc.
2- how can i decrease photons density till i reach one photon
any answer??
FAQ: A gear that i don't know its name
What is a gear that I don't know its name?
A gear is a mechanical device that has teeth or cogs that mesh with other gears to transmit power and motion.
How does a gear work?
A gear works by using its teeth to interlock with the teeth of another gear, which then causes rotation and movement.
What are the different types of gears?
There are several types of gears, including spur gears, bevel gears, helical gears, worm gears, and rack and pinion gears.
What is the purpose of a gear?
Gears are used to transfer power and motion between two or more rotating shafts in a machine or mechanism.
How do I identify a gear that I don't know its name?
To identify a gear, you can look at its shape, teeth size and number, and the type of teeth it has (straight, helical, etc.). You can also consult a gear catalog or ask a specialist for assistance.
