chisigma
MHB
- 1,628
In www.mathhelpforum.com and interesting question has been proposed by the user misiazeska the 05 20 2013...How to find the inverse of this function?...$$y= 5\ x^{3} - x^{5}$$ ... and the unanimous answer has been '... it doesn't exist any closed formula to find x as function of y...'. In my opinion the proposed problem is a good opportunity to use the following solving procedure to find the inverse of an analytic function. Giving a function...$$ w = f(z) = a_{1}\ z + a_{2}\ z^{2} + a_{3}\ z^{3} + ... ,\ a_{1} \ne 0\ (1)$$
... which is analytic inside a disk with $|z|< r$, the Taylor expansion of the inverse function is...$$ z = f^{-1}(w) = b_{1}\ w + b_{2}\ w^{2} + b_{3}\ w^{3} + ...\ (2)$$
... where...$$b_{n}= \frac{1}{n!}\ \lim_{z \rightarrow 0} \frac{d^{n-1}}{d z^{n-1}} \{\frac{z}{f(z)}\}^{n}\ (3)$$
Now we consider the original function...$$y= 5\ x^{3} - x^{5} \implies \sqrt[3]{y}= \sqrt[3]{5}\ x\ \sqrt[3]{1 - \frac{x^{2}}{5}}\ (4) $$
... that, setting $w= \sqrt[3]{y}$ and $x=z$ becomes...$$w = f(z) = \sqrt[3]{5}\ z\ \sqrt[3]{1 - \frac{z^{2}}{5}}\ (5) $$
... which satisfies the requirements of (1) so that the (2) and (3) can be applied. The coefficients $b_{n}$ are computed as follows...
$$b_{1}= \lim_{z \rightarrow 0} \frac{z}{f(z)}= \lim_{z \rightarrow 0} \frac{1}{\sqrt[3]{5}\ \sqrt[3]{1 - \frac{z^{2}}{5}}} = \frac{1}{\sqrt[3]{5}}\ (6) $$
$$b_{2}= \frac{1}{2}\ \lim_{z \rightarrow 0} \frac{d}{d z} (\frac{z}{f(z)})^{2} = \frac{1}{2}\ \frac{1}{\sqrt[3]{25}}\ \lim_{z \rightarrow 0} \frac{d}{d z} \frac{1}{(1 - \frac{z^{2}}{5})^{\frac{2}{3}}} = \frac{1}{2}\ \frac{1}{\sqrt[3]{25}}\ \lim_{z \rightarrow 0}\ \frac{4\ z}{15\ (1-\frac{z^{2}}{5})^{\frac{5}{3}}} = 0\ (7)$$
$$b_{3} = \frac{1}{6}\ \lim_{z \rightarrow 0} \frac{d^{2}}{d z^{2}} (\frac{z}{f(z)})^{3} = \frac{1}{6}\ \frac{1}{5}\ \frac{d^{2}}{d z^{2}}\ \frac{1}{1-\frac{z^{2}}{5}} = - \frac{1}{30}\ \lim_{z \rightarrow 0}\ \frac{10\ (3 z^{2}+5)}{(z^{2}-5)^{3}} = \frac{1}{75}\ (8)$$
... and now we can write the first three terms of the inverse function...
$$ x= \sqrt[3]{\frac{y}{5}} + \frac{y}{75} + ...\ (9)$$
Of course it is possible to proceed to compute more terms but the main scope is to illustrate a way to find a general way to solve this type of problems. For completeness sake in next post I will try to demonstrate the (3)...
Kind regards
$\chi$ $\sigma$
Questions and comments should be posted here:
http://mathhelpboards.com/commentary-threads-53/commentary-general-way-find-inverse-functions-4929.html
Kind regards
$\chi$ $\sigma$
