A glass and bottle of water moving on their own
In summary: Are there any other objects in the room that could have moved (e.g. a plant)?There are no other objects in the room that could have moved (e.g. a plant).
Goat44
Hi all. I'm a bit confused. I was lying in bed last night - on one side of a very big bed, not moving. When all of a sudden I heard a big crashing sound of things moving and falling. I switched the light on and on the bedside cabinet on the opposite side to me, a half full bottle of water and a pint glass half full of water had fallen off and were both on the floor. A little freaked out by this as I hadn't moved at all. I was well over a metre away, there was no gust of wind or any kind of vibration nearby. Can anyone explain this under the laws of physics? I'm beginning to doubt my sanity!
Scary!
I have seen a glass move, apparently of its own accord on a polished surface. If the bottom of the glass was wet (recently filled) and if there was a bubble of air trapped underneath then an increase in room temperature could expand the air and lift the glass enough to let it slide downhill. Check the table top is level (use the water level or use a ball bearing). That could be an explanation.
Good luck ghost hunting.
Likes Steelwolf
sophiecentaur said:
Scary!
Thanks Sophie. It was late at night so the air temp probably would have dropped. The surface is totally level...eek! I don't like it!
rats
anorlunda said:
rats
pretty sure it's not rats! Although they would preferable to a poltergeist!
Bottle:
Capped tightly? Carbonated? How long at room temperature? Material (plastic, glass, insulated, etc)? Distance from glass? Distance to table edge? Flat, dimpled, or ridged base?
Glass:
Material? Capacity? Time last moved? Distance to edge of table? Touching bottle? Diameter/height ratio? Base configuration?
Room:
Humidity? Changing up/down? Temperature? Dewpoint? Air pressure up/down?
Not that an answer is possible, but more information is wanted before guessing.
I experienced something similar about 2 decades ago. My newlywed wife and I lived in an apartment at the time (no pets [or rodents for that matter]) in an aseismic region. We had an entertainment system with speakers on either side. The system was not turned on. Each speaker had several books propped up and 1 qt glass canning jars filled with marbles were used as bookends. I'm a heavy sleeper and usually do not wake from noises, but after a loud crash and the sound of glass breaking I stirred awake. Upon inspection, the books where one jar served as a bookend were still upright, and a light dust ring 3-4 in. on three sides of the jar, still showed where the jar sat prior to crashing to the ground. The other jar remained unmoved. I have no explanation for it.
Multistory buildings have a native frequency (hum), even in the cellar. Depending upon the positioning of your glass objects (e.g. over a beam) this could transfer mechanical energy to the night-stand or speakers (resonant amplification possible?). Combined with moisture (previous post), or dust (observation of rings), a slight incline, and time, et voila, crash, bang, boom, in the night, no poltergeist required.
As others have mentioned, glasses sitting in a small puddle of water of their own condensation can spontaneously slide around. I've seen it myself. It can be freaky.
This is not the only possible answer, but it is probably the simplest.
Likes Klystron
Yep, it's probably this. There's videos on youtube showing/explaining it.
My wife & I were at a local Asian restaurant and the stainless steel teapot started moving around on the formica table top. Spooky. I think the table was damp from being wiped down, and it may have been a bit off-level. I'm sure the hot tea had some part to play as well.
Definitely. The air under the teapot would have been heating up and expanding, pushing its way out around the rim.
Likes russ_watters
Likes Paul Colby, sophiecentaur and gmax137
I did consider this. The apartment was two stories (so technically "multistory"), but I assume that a mechanical transfer mechanism that would otherwise go unnoticed by other senses would likely be passive and slow moving. The fact that the books were still upright leads me to believe that the surface was relatively flat (e.g. heavy speaker). If it were a slow-moving mechanical transfer mechanism I would think that the dust ring (albeit light [I'm pretty tidy]) would show a trail or disruption of some kind if the jar scooted on it's own.
But... just because I'm not familiar with an infrasonic source that transfers mechanical energy relatively quickly doesn't mean it doesn't exist. Does anyone happen to know of such a source?
A washing machine on fast spin?
Likes alva3 and Bystander
"any kind of vibration nearby "
Humans are not very sensitive seismometers.
We were 6400 km away from the 27-Oct-2012 7.8 magnitude Haida Gwaii earthquake
https://en.wikipedia.org/wiki/2012_Haida_Gwaii_earthquakeAll of the pendant lamps in the home began swaying in time with one another around 9:10 MDT, but nothing else noticeable was occurring.
My uncle from the Netherlands asked what was happening.
For sh!ts and giggles, off the cuff, I said "an earthquake probably!"
Went home and turned on the news at 11 PM to find out that it had been an earthquake -- a very, very distant one.
Resonance is a funny thing.
Trains, Harley's, planes, choppers, big trucks--they all create vibration that propagates farther from source than you might think. If something gets resonant with that vibration, it can seem like poltergeists are moving it -- like all the pendant lamps did that night.
Inquire with the USGS if there was a seismic event that night.
Likes WWGD, alva3 and sophiecentaur
That would certainly do the trick, LOL! I wonder how many times washing machines have mistakenly been attributed to the paranormal?
Unfortunately I do not remember the exact date, otherwise I would certainly look it up on USGS. Thanks for the information!
My clothes came out spooky clean last time. All white, even ones that were originally red! ;).
  • Haha
Likes alva3
Related to A glass and bottle of water moving on their own
1. What is the cause of a glass and bottle of water moving on their own?
The most likely cause of a glass and bottle of water moving on their own is due to vibrations or movement in the surface they are resting on. This can be caused by external factors such as a passing vehicle or footsteps, or internal factors such as temperature changes or air flow.
2. Can static electricity cause a glass and bottle of water to move on their own?
Yes, static electricity can potentially cause a glass and bottle of water to move on their own. This is because static electricity can create an imbalance of charges, causing objects to be attracted or repelled from each other. This can result in movement or even levitation of the glass and bottle.
3. Is it possible for a glass and bottle of water to move on their own without any external or internal factors?
No, it is not possible for a glass and bottle of water to move on their own without any external or internal factors. The laws of physics dictate that objects cannot move without a force acting upon them. Therefore, there must be some sort of external or internal force causing the movement of the glass and bottle.
4. Can a ghost or paranormal activity be the cause of a glass and bottle of water moving on their own?
There is no scientific evidence to support the idea that ghosts or paranormal activity can cause a glass and bottle of water to move on their own. The most likely explanation is still external or internal factors, as mentioned before.
5. How can we prevent a glass and bottle of water from moving on their own?
To prevent a glass and bottle of water from moving on their own, it is important to eliminate any potential external or internal factors that could be causing the movement. This can include placing the glass and bottle on a stable and level surface, minimizing vibrations in the surrounding area, and controlling temperature and air flow. Additionally, using objects with a wider base or adding weight to the glass or bottle can also help prevent movement.
  • Earth Sciences
  • Other Physics Topics
  • Mechanics
