ahmed11
- 83
what will happen when a grenade blow up in a room without air in it?
will it make the same damage as it would in a regular room?BvU said:There will be less noise for the neighbors.
The fragmentation holes in the walls will be a bit deeper.ahmed11 said:will it make the same damage as it would in a regular room?
Yes, a grenade can still explode in a room with no air. The explosion is caused by the ignition of the explosive material inside the grenade, not by the presence of oxygen.
The explosion itself will not be significantly different in a room with no air. However, the lack of oxygen may result in a smaller fireball and less intense flames.
Yes, there will still be a shockwave from the explosion in a room with no air. The shockwave is created by the rapid expansion of gases from the explosion, not by the presence of oxygen.
Yes, a grenade can still cause damage in a room with no air. The explosion and shockwave can still cause physical damage to objects and structures in the room.
No, it is not safe to be in a room with no air when a grenade explodes. The explosion and shockwave can cause serious injury or death, and the lack of oxygen can also lead to asphyxiation.
