A hydrogen atom transitions from n= 5 state to the ground state
In summary, the "n= 5 state" refers to the fifth energy level or shell of the hydrogen atom, while the "ground state" refers to the lowest energy level or shell. A hydrogen atom can transition from the n= 5 state to the ground state by releasing energy in the form of a photon, causing a decrease in energy. Similarly, it can transition from the ground state to the n= 5 state by absorbing energy in the form of a photon. These transitions demonstrate the quantization of energy in atoms and follow the energy levels predicted by the Bohr model of the atom.
ikihi
81
A hydrogen atom transitions from ni= 5 state down to the ground state.
a) What is the energy of photon emitted from the transition of the hydrogen atom?
b) What is the ratio of the momentum of the emitted photon to the momentum of an electron which possesses the same kinetic energy as that of the photon. That is calculate pe/pγ.
ΔEphoton = Ef - Ei
En= -13.6 eV / (n)2
a)
ΔEphoton = E1 - E5
ΔEphoton = -13.6 eV [1/(1)2 - 1/(5)2] = - 13.0 eV = - 2.08 x 10 -18 J (shouldn't the answer here be positive?)
b)
Momentum of electron
Pelectron = √(2 ⋅ m ⋅ Ephoton)
Pelectron = √(2 ⋅ 9.11 x 10-31 ⋅ 2.08 x 10 -18)
Pelectron = 1.95 x 10-24
Momentum of photon
Pphoton = h /λ = Ephoton / c = (2.08 x 10-18) / (3.00 x 108)= 6.97 x 10-27
Ratio
Pelectron / Pphoton = 1.95 x 10-24 / 6.97 x 10-27 = 280
The answer should be positive. Your initial formula gives the correct sign if you absorb a photon.
Working with eV everywhere would make calculations easier, but working with SI units is possible as well, of course.
So I'm using the wrong formula for photon emission?
You can just change the sign at the end. Or use the absolute value of the energy difference, then it works in both cases.
Signs should come from understanding the situation. Good if the formulas also have the correct sign, but you should understand which sign the result has to have.
Related to A hydrogen atom transitions from n= 5 state to the ground state
1. What do the "n= 5 state" and "ground state" refer to in a hydrogen atom?
The "n= 5 state" refers to the fifth energy level or shell of the hydrogen atom, where the electron is located. The "ground state" refers to the lowest energy level or shell, where the electron is most stable.
2. How does a hydrogen atom transition from n= 5 state to the ground state?
A hydrogen atom can transition from the n= 5 state to the ground state by releasing energy in the form of a photon. This process is known as emission or spontaneous decay.
3. What happens to the energy of the hydrogen atom during this transition?
During the transition from n= 5 state to the ground state, the energy of the hydrogen atom decreases. This is because the electron moves from a higher energy level to a lower energy level, releasing energy in the form of a photon.
4. Can a hydrogen atom transition from the ground state to the n= 5 state?
Yes, a hydrogen atom can transition from the ground state to the n= 5 state by absorbing energy in the form of a photon. This process is known as absorption or stimulated emission.
5. What is the significance of a hydrogen atom transitioning from n= 5 state to the ground state?
This transition is significant because it follows the energy levels predicted by the Bohr model of the atom. It also demonstrates the quantization of energy in atoms, where the electron can only exist in specific energy levels or shells.
