A Lagrangian approach to the Barrett-Crane spin foam model-Livine Bonzom
In summary, the paper titled "A Lagrangian approach to the Barrett-Crane spin foam model" by Valentin Bonzom and Etera R. Livine presents a discrete action principle for the Barrett-Crane spin foam model for quantum gravity. This approach involves imposing discretized simplicity constraints on disjoints tetrahedra and using a non-commutative product between SU(2) plane waves to construct the discretized BF action. The paper also discusses the natural generalization of this action principle and how it leads to different spin foam models, including the Engle-Pereira-Rovelli model. Finally, the paper identifies the two sectors of Plebanski's theory and gives an analog of the Barrett-C
marcus
Dearly Missed
24,775
792
A Lagrangian approach to the Barrett-Crane spin foam model--Livine Bonzom
Here's a paper helping to sort out the situation with spinfoams. I think it is probably important. Actually we've been anticipating something of this caliber. Back in October I put in a placeholder for an expected Livine paper to be nominated for this quarter's MIP.
Earlier this year there was a Freidel paper showing an action-based path integral formulation for several spinfoam models. This paper seems aimed in a similar direction.
http://arxiv.org/abs/0812.3456
Valentin Bonzom, Etera R. Livine
25 pages, 4 figures
(Submitted on 18 Dec 2008)
"We provide the Barrett-Crane spin foam model for quantum gravity with a discrete action principle, consisting in the usual BF term with discretized simplicity constraints which in the continuum turn topological BF theory into gravity. The setting is the same as usually considered in the literature: space-time is cut into 4-simplices, the connection describes how to glue these 4-simplices together and the action is a sum of terms depending on the holonomies around each triangle. We impose the discretized simplicity constraints on disjoints tetrahedra and we show how the Lagrange multipliers for the simplicity constraints distort the parallel transport and the correlations between neighbouring 4-simplices. We then construct the discretized BF action using a non-commutative product between SU(2) plane waves. We show how this naturally leads to the Barrett-Crane model. This clears up the geometrical meaning of the model. We discuss the natural generalization of this action principle and the spin foam models it leads to. We show how the recently introduced spinfoam fusion coefficients emerge with a non-trivial measure. In particular, we recover the Engle-Pereira-Rovelli spinfoam model by weakening the discretized simplicity constraints. Finally, we identify the two sectors of Plebanski's theory and we give the analog of the Barrett-Crane model in the non-geometric sector."
I wonder how he will put fields in that... I am clueless.
I am excited to see this paper addressing the long-standing issue of finding an action-based path integral formulation for the Barrett-Crane spin foam model. This approach not only provides a clearer geometrical interpretation of the model, but also opens up possibilities for generalizations and extensions to other spinfoam models. The inclusion of the Engle-Pereira-Rovelli spinfoam model and the identification of the two sectors of Plebanski's theory are also significant contributions to the field. I look forward to further developments and applications of this Lagrangian approach in quantum gravity research.
Related to A Lagrangian approach to the Barrett-Crane spin foam model-Livine Bonzom
1. What is the Barrett-Crane spin foam model?
The Barrett-Crane spin foam model is a quantum gravity model that aims to describe the dynamics of space-time at a microscopic level. It is based on the principles of loop quantum gravity and uses spin networks to represent the geometry of space-time.
2. What is a Lagrangian approach?
A Lagrangian approach is a mathematical approach used in physics to describe the dynamics of a system. It involves defining a Lagrangian function, which represents the energy of the system, and using the principle of least action to determine the equations of motion.
3. How does the Lagrangian approach relate to the Barrett-Crane spin foam model?
The Lagrangian approach can be used to derive the equations of motion for the Barrett-Crane spin foam model. This allows for a better understanding of the dynamics of the model and can lead to new insights and predictions.
4. What is the significance of Livine Bonzom's contribution to the Barrett-Crane spin foam model?
Livine Bonzom's work introduced a new mathematical framework for the Barrett-Crane spin foam model, known as the "EPRL-FK model". This framework allows for a more complete and consistent treatment of the model, leading to more accurate predictions.
5. What are some potential applications of the Lagrangian approach to the Barrett-Crane spin foam model?
The Lagrangian approach to the Barrett-Crane spin foam model has the potential to provide a deeper understanding of the fundamental nature of space-time and could potentially lead to new insights in quantum gravity. It may also have practical applications in fields such as cosmology and high-energy physics.
  • Beyond the Standard Models
