A Leaning Plank. Find where it looses contact.
  • Thread starter warjunkie
  • Tags
    Contact
In summary: Sorry for the confusion, can somebody please elaborate on what is going on here?The uniform plank of length L leans against a vertical wall, its head a distance h above the horizontal ground. If we let go of the plank from rest, how far above the ground is the head of the plank the moment it loses contact with the wall?In summary, the head of the plank is a distance h above the ground the moment it loses contact with the wall.
warjunkie
A uniform plank of length L leans against a vertical wall, its head a distance h above the horizontal ground. If we let go of the plank from rest, how far above the ground is the head of the plank the moment it loses contact with the wall?
Fx=0
Fy=mg
I'm not sure but wouldn't the head of the plank never lose contact with the wall,
since there is no x-direction forces.
In my knowledge, I only see y- direction force, which is mg (Mass of the plank and gravity), which causes the head of the plank to just fall all the way without losing contact with the wall.
Am I correct?
hi warjunkie! :smile:
(is there friction? :confused:)
there are three forces on the plank, not one …
the weight, and the reaction force from the wall and from the ground …
start again​
Do you know what the answer is. If that is so please post it. That we can do our individual calculations and then be sure and help you.
tiny-tim said:
hi warjunkie! :smile:(is there friction? :confused:)
start again​
Alrighty, thanks for the post. I'll try it again!
And i don't think friction exists in this problem...
mg -Ng = m*ay
Nw=m*ax
weight=mg= mass x gravity
Ng= normal force from the ground
Nw=normal force from the wall
ay= y-acceleration
ax= x-acceleration
ay = ax? since the plank is one object and if the head slips down, the bottom also slips with same distance/speed.
These are my new equations... but I still don't see why the plank will lose contact with the wall...
wouldn't the y-distance lost by sliding down will always be compensated by the increase in x-distance?
Unfortunately, there's no answer :(
It's an extra credit problem that was posted by my professor.
noooo :redface:
(use Pythagoras or trig)
it will if ax is zero …
what is the equation for ax ?
Unfortunately, this thread had stopped to continue before the answer was achieved.Though I am not the OP I would like to resume it. Please help me to get the answer.
ashishsinghal said:
… Though I am not the OP I would like to resume it. Please help me to get the answer.
hi ashishsinghal! :wink:
show us what you've done, and where you're stuck, and then we'll know how to help! :smile:
First of all I am not able to understand why the rod will lose contact with the wall.
Let the height of ladder be y and its horizontal distance be x
then
x2 + y2 = const
x*dx/dt + y*dy/dt=0
x*dx/dt = y*vy
here vy is the vertical velocity of the rod and vy = -dy/dt
hence
vx=tan[tex]\theta[/tex]vy
then,
ax=tan[tex]\theta[/tex]ay
for center of mass : acom,x = ax/2
and similarly for y
we know Macom,x = Nw(normal from wall)
also Macom,y = Mg - Ng
But this cannot give me time. I know that Nw is zero at the required time. I am stuck!
conservation of energy? :wink:
But it would not give me time, also is my attempt correct?
Theta changes during the motion, you can not ignore its time derivatives. Express x and y with theta and write the equations for acceleration of CM and the rotation around the CM in terms of theta and its time derivatives. The time is not needed to find the value of theta where the normal force from the wall is zero.
ehild
Oh, my mistake I thought the question is "Find the time when it loses contact"
Can anyone please first tell me that why will the plank lose contact? If it loses contact ax =0 then either tan[tex]\theta[/tex]=0 or ay=0 (using equations from my earlier post). If tan[tex]\theta[/tex] is zero then it lies horizontal. If ay is zero then Ng = Mg. Also for rotational equilibrium [tex]\tau[/tex]Mg = [tex]\tau[/tex]N. Hence plank needs to be horizontal.
Revise your equations.
x=Lsinθ,
vx= dx/dt=Lcosθ dθ/dt,
ax=dvx/dt=
= -Lsinθ(dθ/dt)2+Lcosθ d2θ/dθ2
and so on...
You can also write up the Lagrangian in terms of theta and get the relationship between theta and derivatives from the Euler equation.
ehild
ehild said:
You can write up the Lagrangian in terms of theta.
ehild
What is Lagrangian? Please first tell me why will the plank lose contact.
For Euler-Lagrange equations, see http://www.physics.thetangentbundle.net/wiki/Classical_mechanics/Euler-Lagrange_equations
If you are not familiar with it, write up the equation of motions for the CM and rotation about the CM.
I do not know when the plank loses contact. That is this problem for.
ehild
Conservation of energy provides also a very easy solution. Write up the total mechanical energy in therms of theta, find the angular speed and acceleration, from that you can get ax, and solve for ax=0.
ehild
for center of mass : vcom,x = vx/2
and similarly for y
So in the frame of com the plank is doing rotational motion with angular velocity = sqrt(vx2/4 + vy2/4)/(L/2)
=sqrt(vy2tan2[tex]\theta[/tex]/4 + vy2/4)/(L/2)
=vysec[tex]\theta[/tex]/L
From this I can find energy. Is all this correct?
Now Rotational KE = 1/2*M[STRIKE]L[/STRIKE]2/12 * (vysec[tex]\theta[/tex]/[STRIKE]L[/STRIKE])2
Translational KE = 1/2*M(vysec[tex]\theta[/tex])2
Potential energy = Mg*Lsin[tex]\theta[/tex]/2
I think I have calculated everything required. But I have not received any confirmation if the calculations are correct or not. Please do so.
Also I am mainly having a conceptual problem over here. I am not able to understand why it will lose contact. I am not able to visualize it. Please help me do the same. I would be highly thankful.
You made quite a few mistakes :)
vx/vy = - tan(θ).
The translational KE is
1/2 *m ( (vx/2)2+(vy/2)2)
Potentional energy = mgL/2 cos(θ)
The question if the plank loses contact is answered by the solution of the problem. I can not explain it in words. The answer is a derivation which results in a distance x or angle theta when the force from the wall is zero, and would be negative after that instant if the same equations hold. But the force can not be negative, you have a different problem from that instant. It is just a plank, touching the ground in one point , traveling away from the wall and falling at the same time so the edge on the ground has higher horizontal speed than the other one.
Anyway, a little experiment can help. I tried it with a ruler and a book as wall, and it lost contact , in spite of friction.
ehild
when it gets verrrrry close to the ground, if it was still in contact with the wall, its velocity would be very nearly vertical …
ie its horizontal velocity would be very small …
so at some point the horizontal velocity has to start decreasing, which is not possible since there is no force towards the wall :wink:
Tiny-Tim, I like your explanation so verrrrrrrrrrry much :)ehild
ehild
I agree with echild.    The fish RULES !
So should I use conservation of energy to find θ for which vx is max
Yes. I would say ax=0, but it is at the same time when the velocity of the bottom point of the plank reaches its maximum value.
ehild
:smile:
When I first joined PF, I read ehild as 'echild' everytime.
Abdul Quadeer said:
:smile:
Never mind. Don't you want to show a solution? If I do I will get a serious warning. But you can present yours and ask if it is correct. It would be a pity to left this very nice problem unsolved.
ehild
I already solved the question b4 posting :smile:
I used energy-conservation, Lagrange's equations and a bit of math to get the answer as h/3.
I tried using the simple torque approach in place of Langrangian's method but I got a sign change.
Let the length of the plank be 2l (for simplicity) and let it make an angle θ with the horizontal when normal force by the vertical wall is 0.
1. Energy Conservation-
ω2 = 3g/2l (sinΦ - sinθ), where Φ is the initial angle of the base with horizontal.
2.
Angular acceleration of the rod when N=0 = α = -ω2cotθ
aCOM along vertical direction = -lω2sinθ + lαcosθ
3. Torque
N2cosθ = mlα/3, where N2 is the normal force by the ground
(Takin the extreme case when N=0)
Also,
N2 = m(g-aCOM along vertical direction)
Substituting and simplifying, I got ω2 = -3gsinθ/4l
whereas ω2 = +3gsinθ/4l using Lagrange's method.
I have an intuition that there is some problem with the torque method.
  • #31
Correct so far, but I but I can not follow you after. I write the details to get the angular acceleration
The angular acceleration is obtained by derivation of
ω2=3g/(2L) (sinΦ - sinθ). *
2ω dω/dt=-3g/(2L)(cosθ)ω --->dω/dt=-3g/(4L)cosθ. **
N=0 means that the horizontal acceleration of the centre of mass is zero. The x coordinate of the CM is xcm=L(cosθ), vcm=-Lω(sinθ) and
acm=-L*(ω2cosθ +dω/dt sinθ ).***
acm=0 means that dω/dt =-ω2cotθ, the same you got.
Substituting (*) for ω2 and (**) for dω/dt in (***) for the horizontal acceleration, you get the angle when the contact is lost.
I do not understand the signs in your torque method. Show what you consider positive directions. Also, dω/dt is missing from your equation for N2. And you got an expression (*) for ω2 already, what are these different new ones?
ehild
  • #32
No need of any Langrangian or torque equations?
ehild
I took upward direction positive. dw/dt = α in my equations.
I solved for α from the torque equation and Newton's law to find one more expression for α and hence ω.
btw I got the height as 2h/3 not h/3
  • #33
No need any of them, just get the accelerations dω/dt and ax by derivation with respect to time.
Check the signs in your equations. But the torque method is quite complicated.
2h/3 is correct. Great work!
First I wrote up the equations of motion for the translation of the CM and for the rotation around it. It was quite complicated. Then I used the Lagrangian to find the equation of motion in terms of the angle. But I had to solve a differential equation to get the angular speed. The easiest way was using conservation of energy.
ehild
  • #34
Thanks to all for this wonderful effort. I am really thankful.Never could have possibly got to that without your help.
Special thanks to ehild.:smile:
FAQ: A Leaning Plank. Find where it looses contact.
1. What is a leaning plank?
A leaning plank is a long, flat piece of wood or other material that is tilted at an angle, rather than being completely horizontal.
2. Why does a leaning plank lose contact?
A leaning plank can lose contact due to the force of gravity pulling it towards the ground, causing it to slip or fall.
3. What factors can affect where a leaning plank loses contact?
The weight and distribution of weight on the plank, the angle of the lean, and the surface it is resting on can all affect where a leaning plank loses contact.
4. How can you find where a leaning plank loses contact?
By measuring the angle of the lean and using trigonometric equations, you can determine the point at which the plank will lose contact with the surface it is resting on.
5. Can a leaning plank be stabilized to prevent it from losing contact?
Yes, a leaning plank can be stabilized by adding weight to the opposite end or by propping it up with an object to counteract the force of gravity pulling it downwards.
