MHB A line passing through two points
  • Thread starter Thread starter Guest2
    Line Points
To find the value of \( a \) for the point \( (a, 4, -3) \) on the line through points \( p = (1,2,-1) \) and \( q = (3,1,0) \), the correct calculation shows that \( a = -3 \). The line can be expressed parametrically as \( (x,y,z) = (1,2,-1) + t(2,-1,1) \). By solving the equations derived from the line's parameters, it is confirmed that \( t = -2 \) leads to \( a = -3 \). However, the initial methodology had inaccuracies, particularly regarding the relationship between the line and the plane generated by points \( p \) and \( q \). The final conclusion is that \( a = -3 \) is indeed correct.
Guest2
If the line passing through the points $p = (1,2,-1)$ and $q = (3,1,0)$ contains the point $(a, 4,-3)$ then what's the value of $a$?
I think $a = -3$. but I'm not sure.
$(1,2,-1)x+(3,1,0)y = (a,4,-3)$
$(x,2x,-x)+(3y,y,0) = (a,4,-3)$
$(x+3y, 2x+y, -x) = (a, 4,-3)$
so $x = -3$, $y = -2$ and $a = -3$
Mathematics news on Phys.org
Your answer is correct, although the methodology is not as good as you might hope.
Firstly, you have a typo, it should be $x = 3$.
Secondly, although the line going through $p$ and $q$ does lie in the plane generated by $p$ and $q$, it is not true that any point in the plane so generated lies on that line. So you kind of got lucky.
The line through $p$ and $q$ is:
$\{(x,y,z) \in \Bbb R^3: (x,y,z) = p + t(q-p), t \in \Bbb R\}$.
We have:
$q - p = (2,-1,1)$, so our line is:
$(1,2,-1) + t(2,-1,1)$
so: $(2t+1,2-t,t-1) = (a,4,-3)$
Either $2-t = 4$ or $t-1 = -3$ leads to $t = -2$, and consequently $a = 2t + 1 = 2(-2) + 1 = -4 + 1 = -3$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
