A link from complex number to hypercomplex numbers
In summary, the discovery of complex numbers was motivated by the need to solve real number problems, specifically finding square roots of negative numbers. This led to the extension of numbers to include complex numbers. However, there is no similar problem that uses complex numbers only and has no complex number solution, which would require the introduction of hypercomplex numbers. Hypercomplex numbers were discovered by adding extra dimensions to complex numbers, and can be further explored by researching Google quaternions or hypercomplex numbers.
Den Webi
If i understand correctly, the discovery of complex numbers was linked to solving real number problems, s.a. finding square roots of negative numbers. In other words, at first there was a problem that was formulated using real numbers only that had no real number solutions, which lead to extending the concept of numbers to include complex numbers.
Is there a similar problem that uses complex numbers only but has no complex number solution and requires the introduction of hypercomplex numbers?
Or is it that hypercomplex numbers were discovered/invented by simply adding extra dimensions to complex numbers?
Thank you in advance!
Mathematics news on Phys.org
Khashishi, thank you so much, that's exactly what i was looking for!
Related to A link from complex number to hypercomplex numbers
1. What is a complex number?
A complex number is a number that can be written in the form a + bi, where a and b are real numbers and i is the imaginary unit. The imaginary unit is defined as the square root of -1, and it is denoted by the letter i.
2. How are complex numbers related to hypercomplex numbers?
Complex numbers are a subset of hypercomplex numbers. Hypercomplex numbers are a generalization of complex numbers that involve more than one imaginary unit. For example, quaternion numbers involve three imaginary units.
3. What are some applications of hypercomplex numbers?
Hypercomplex numbers have many applications in mathematics, physics, and engineering. They are used in 3D computer graphics, robotics, control systems, and signal processing. They are also used in studying the behavior of physical systems, such as fluid dynamics and electromagnetism.
4. Can hypercomplex numbers be represented visually?
Yes, hypercomplex numbers can be represented visually in a 3D space. Just like how complex numbers can be represented on the complex plane, hypercomplex numbers can be represented on a 3D coordinate system. This allows for a better understanding and visualization of their properties and operations.
5. Are there any real-life examples of hypercomplex numbers?
Yes, there are many real-life examples of hypercomplex numbers. For instance, in robotics, quaternion numbers are used to represent and manipulate 3D rotations and orientations. In physics, Dirac algebra, a type of hypercomplex numbers, is used to describe the behavior of elementary particles.
  • General Math
  • General Math
  • General Math
