A little confusion over x and y values
  • Thread starter hivesaeed4
  • Tags
    Confusion
In summary, x and y values refer to the two variables in a coordinate system, with x representing the horizontal position and y representing the vertical position. To plot them on a graph, a scale is chosen for each axis and points are marked and connected. Switching the values will result in a rotated graph. X and y values can be negative, depending on their position in relation to the origin. In mathematical equations, x and y values represent the independent and dependent variables, respectively.
hivesaeed4
217
Suppose a function is defined as:
f(x,y)=0 for x=y=0
Does this mean that the function would be zero when both x and y are xero or when either one of them are zero?
f(x,y)=0 for x=y=0
It means that at the origin (x,y)=(0,0) or as you write x=y=0, that the function f(x,y)=0.
I.e. when BOTH are zero.
Thanks.
FAQ: A little confusion over x and y values
What is the difference between x and y values?
X and y values refer to the two variables in a coordinate system. The x value represents the horizontal position of a point, while the y value represents the vertical position. In other words, the x value tells you how far left or right a point is, and the y value tells you how far up or down.
How do you plot x and y values on a graph?
To plot x and y values on a graph, first decide on a scale for each axis. Then, for each pair of x and y values, find the corresponding point on the graph and mark it. Finally, connect the points to create a line or scatter plot.
What happens if the x and y values are switched?
If the x and y values are switched, the resulting graph will be rotated 90 degrees counterclockwise. This is because the x value now represents the vertical position and the y value represents the horizontal position.
Can x and y values be negative?
Yes, x and y values can be negative. In a coordinate system, the x axis extends to the left and right, while the y axis extends up and down. Therefore, points can have negative x and y values depending on their position in relation to the origin (0,0).
How do x and y values relate to mathematical equations?
X and y values are used to represent the independent and dependent variables in mathematical equations. The x value is usually the independent variable, meaning it can be changed freely, while the y value is the dependent variable, meaning it is affected by changes in the x value.
