A man pulls himself up;What force does he exert on the elevator?
In summary, the man pulling himself up in an elevator with an acceleration of 1 m/s², and the masses of the man and elevator being 60 kg and 40 kg respectively, can be summarized as follows: The tension in the rope can be calculated using the equation Fr = Ma, with the result being 550N. To calculate the force that the man exerts on the elevator's floor, the man's free body diagram must be drawn, with his weight and the elevator's normal force being equal and opposite, resulting in a net force of
ShizukaSm
85
A man pulls himself up, the acceleration is 1 m/s², the man's mass is 60 kg and the elevator's mass is 40 kg.
a) Calculate the tension in the rope.
b) Calculate the force that the man exerts on elevator's floor.
Fr = Ma
I calculated letter a) correctly, and found 550N. My problem is on letter b).
Here are my thoughts: The man's free body diagram on the elevator would be: His weigh down, and the elevator's normal (opposing to the force he exerts by Newton's 3rd law) up, the difference of those would accelerate him, so, in symbols:
[itex]
N_{elevator} - P_{man} = m_{man}a\\\\
a = 1\frac{m}{s^2}; P_{man} = 588 N;\\
N_{elevator} = 588 + 60 = 648N
[/itex]
However, the answer is supposed to be 110 N. I also noticed that 648N - 550 N is almost equal to 110N, however that doesn't make much sense, since there are two tensions acting on him, and not only one.
Thanks in advance.
Fr = Ma
[itex]
[/itex]
Thanks in advance.
When you draw the FBD of the man, yes, the normal force of the floor on the man acts up, and his weight acts down, but there is tension acting on him also, but if you look closely, is it one or 2 tensions acting on him?
I suppose it's one, but I don't understand why. I see the two tensions acting on him (the one that's acting on his hand, and the one acting on top of the elevator).
Ooohhhh... wait. The one acting on the elevator ISN'T acting on him, it's, as the name implies acting on the elevator. The only tension acting on the man is the one acting on his hand then.
Is this correct?
Is this correct?
Yes, correct. When you look at the FBD of the man-elevator system, there are 2 tensions acting on the system, which I gather you realized by obtaining the corect solution to part a. But only one on the man and the other on the elevator. Drawing the FBD of the man only allows you to calculate the normal force of the elevator on the man, and the normal force of the man on the elevator can be found from Newton's 3rd law. As a check, you may want to draw a FBD of the elevator alone to obtain the Normal force of the man on the elevator directly, although this may be a bit more difficult to visualize, but worth a look.
Is this correct?
For part b), you are considering only the forces acting on the man ( he is your system here) so that is why there is only one tension acting on the man. In part a), you considered the system man + elevator so there you had two tensions.
In your opening post, you said that his weight and normal force constitute a third law force pair. That is not right because both these forces act on the same body.
Thanks a lot to you both! It's very clear to me now. Regarding the Weigh and Normal, I got those confused. I should have said that the Weigh of the man applied on the elevator and the Normal applied on the man constitute an action and reaction pair, right?
We have the force of Earth onto man (gravitational force) and force of man onto earth. This is a third law pair since the two forces act on different bodies. The other third law pair is the force from the elevator on man (normal force) and the force from man onto elevator. (as PhanthomJay mentioned).
The 'Weight of man on elevator' you refer to is (I think it is what you mean) this force from man on elevator in my example above.
no, that is not right. Force pairs act on different objects and are equal and opposite. The man's weight (600 N) and the normal force acting on him (110 N) are not the same for one thing. These are 2 distinct forces acting on him, not force pairs. If the man exerts a normal force on the elevator, the elevator exerts a normal force on him of the same magnitude in the opposite direction. If the Earth exerts a force on the man due to gravity (his weight, mg), then the man exerts a force on the Earth in the other direction equal to mg. If the rope exerts a tension force on the man, the man exerts an equal and opposite force on the rope. These are the force pairs.
Related to A man pulls himself up;What force does he exert on the elevator?
1. What is the basic concept behind a man pulling himself up?
The basic concept behind a man pulling himself up is that he is exerting a force on an object, in this case the elevator, to move himself upwards. This force is generated by the man's muscles and is directed towards the elevator.
2. What determines the magnitude of the force exerted by the man?
The magnitude of the force exerted by the man is determined by his weight and the force of gravity acting on him. The heavier the man is, the more force he will need to exert to move himself upwards.
3. Does the direction of the force matter in this scenario?
Yes, the direction of the force does matter. The man's force must be directed towards the elevator in order for him to move upwards. If the force is directed in any other direction, the man will not be able to pull himself up.
4. How does the motion of the elevator affect the force exerted by the man?
The motion of the elevator does not affect the force exerted by the man. The man's force is independent of the elevator's motion and will remain the same as long as he continues to pull himself up.
5. Is the force exerted by the man equal to the force of gravity pulling him down?
No, the force exerted by the man is not equal to the force of gravity pulling him down. The man's force is greater than the force of gravity, which allows him to overcome the force of gravity and pull himself up.
10K
