A mixture of K chloride and K nitrate problem
  • Thread starter skepticwulf
  • Tags
    Mixture
In summary, the original mixture of potassium chloride and potassium nitrate has a 43.2% potassium content.
skepticwulf
74
Consider a mixture of potassium chloride and potassium nitrate that is 43.2% potassium by mass. What is the percent KCl by mass of the original mixture?
x is the mole of KCI in the mixture
y is the mole of KNO3 in the mixture
molar mass of KCl is 74,5g/mol
molar mass of KNO3 is 101g/mol
So, 74,5x+101y=100
Also, K %mass in KCl is 39/74,5=0,5235 and K %mass in KNO3 is 39/101=0,386
So, 0,5235x+0,386y=0,432
2 unknown, 2 equations: x Solved=0,217 ...that is: 0,217x74,5=16,16gr KCl; that's %16,16 in a sample 100gr
But solution manual says it's %32.9KCl
What's wrong with my calculation?
So, 74,5x+101y=100
I think the error is in your second line and specifically in the denominators. Yours verbally sounds plausible, so write out explicitLy mass of K in KCl and mass of K in KNO3. Oops sorry, you have. It's wrong. Mass of K is just moles of K × (atomic mass of K). OK?
Thank you epenguin but I don't understand last part of your reply "Oops sorry, you have. It's wrong. Mass of K is just moles of K X (atomic mass of K). OK?"
Could you kindly elaborate on that?
OK, I thought I had almost given you the answer, how to calculate it anyway, and that you had gone away with that and left the thread unanswered, something that some of the HH are getting fed up with.
The X in my original answer meant ×, multiplication sign - I have only just noticed we have it in the Σ symbols list.
Just forget about percentages and just think about number of moles and number of grams. For just one component at a time, e.g. KCl.
You have x moles of KCl. How many grams of KCl is that? OK, you have that inside your first equation, using molecular mass..
Now how many moles of K are there in x moles of KCl? How many grams of K is that?
If using that you get the right answer please post at least your correct second equation here - see second line of my sig.
Thank you, let me contemplate on that..
Related to A mixture of K chloride and K nitrate problem
1. What is a mixture of K chloride and K nitrate?
A mixture of K chloride and K nitrate is a combination of potassium chloride (KCl) and potassium nitrate (KNO3). These are both ionic compounds composed of potassium ions and either chloride or nitrate ions.
2. How can you separate a mixture of K chloride and K nitrate?
The mixture can be separated by a process called precipitation. This involves adding a solution, such as silver nitrate (AgNO3), which will react with one of the compounds to form a solid precipitate. The precipitate can then be filtered out, leaving the other compound in solution.
3. What are the properties of K chloride and K nitrate?
K chloride and K nitrate have different physical and chemical properties. K chloride is a white, crystalline solid that is soluble in water and has a salty taste. K nitrate is also a white crystalline solid, but it is more soluble in water and is used as a fertilizer in agriculture.
4. What is the purpose of mixing K chloride and K nitrate?
The purpose of mixing these two compounds is to create a solution with a specific concentration of potassium ions. This can be useful in various experiments or industrial processes that require a precise amount of potassium ions.
5. Are there any safety precautions to take when working with a mixture of K chloride and K nitrate?
Yes, both K chloride and K nitrate can be harmful if ingested or inhaled. It is important to wear protective equipment, such as gloves and a mask, when handling these compounds. Additionally, they should be stored and disposed of properly to prevent any potential hazards.
