A new approach: retrocausality in QFT
In summary, the article discusses a new idea that suggests retrocausality might be a real phenomenon. It is not a theory, but rather an alternate interpretation. It is possible that future decisions made in the present could influence properties back in the past, but more evidence is needed to confirm this idea.
Buzz Bloom
467
I looked at the other threads that have discussed retrocausality, but a scan of the article
seems to take a new approach.
The paper also gives two references.
Proceedings of The Royal Society A. DOI: 10.1098/rspa.2016.0607 .
Also at arXiv:1607.07871 [quant-ph].​
The following paragraph is a quote from the article that seems to explain the meaning of the authors' idea.
First, to clarify what retrocausality is and isn't: It does not mean that signals can be communicated from the future to the past—such signaling would be forbidden even in a retrocausal theory due to thermodynamic reasons. Instead, retrocausality means that, when an experimenter chooses the measurement setting with which to measure a particle, that decision can influence the properties of that particle (or another particle) in the past, even before the experimenter made their choice. In other words, a decision made in the present can influence something in the past.
The following is another quote which seems to be the theoretical basis for the idea.
Can't have both time symmetry and no-retrocausality​
I have two questions about this idea.
1. Can any of the forums participants think of a way that this idea can be experimentally tested?
2. What does anyone guess about the chances that this idea will at some future time become mainstream?
Sure, I'll take a shot. :smile:
1. That is more or less the $64,000 question. There are many experiments which have been run that strongly suggest retrocausality. However, competing interpretations are not excluded by such experiments. (Examples include entangling particles after they have been measured, seemingly impossible.)
2. No chance it will become mainstream without more experimental evidence to exclude other interpretations.
I am an advocate of examination of time symmetric class theories/interpretations, including ones featuring retrocausality. From the paper you cited by Leifer/Pusey:
We conclude that the most plausible response to our result, other than giving up Realism, is to posit that there might be retrocausality in nature. At the very least, this is a concrete and little explored possibility that holds the promise of evading almost all no-go theorems in the foundations of quantum theory, so it should be investigated further.
Another approach, along similar lines, is Relational Blockworld. This features a type of time symmetry but is considered "acausal" rather than retrocausal. The distinction being that neither the past nor the future can be considered as causing anything independently. So there is no direction of causal flow.
http://www.ijqf.org/wps/wp-content/uploads/2015/06/IJQF2015v1n3p2.pdf
This includes related discussion to work by Leifer and Price (related to your cited article).
But in discussions here, support for any variation away from forward in time causation is very low.
Likes Buzz Bloom and entropy1
Currently I am considering the acausal correlations between past and future Dr. Chinese mentioned in combination with non-realism, or non-CFD.
Likes DrChinese
What is the distinction between
"...signals can be communicated from the future to the past..."
and
"...that decision can influence the properties of that particle (or another particle) in the past..."
Depends on the decisions made in the future that would influence properties back here in the present, right?
Likes Buzz Bloom
bahamagreen said:
1. What is the distinction between
and
1. If I entangle pairs of particles after they are detected, they will have properties different than if I do not entangle them. But such process cannot be used to send a signal anywhere, the results are still random outcomes as far as we know.
2. The future DrC made me say that. :smile:
Likes vanhees71, Buzz Bloom and Mentz114
I have always viewed retrocausality as an alternate interpretation - not a theory. The problem is not that it doesn't predict anything testable, but that it doesn't predict anything different and testable.
For example, it predicts that the arrow of time is set entirely through thermodynamics and, as the article describes it, boundary conditions. But is there a theory that says otherwise? One that poses an alternative time-arrow theory that is specific enough to test?
I see one immediate advantage in using this interpretation in some discussions: It makes the "interpretation" status of the many-world interpretation (MWI), easier to examine. If you want to reverse the time arrow in MWI, it would seem to me that you need those other worlds you formed to cooperate. If MWI worlds interact in one time direction, why not both? Does MWI presume a fundamental direction of time? If it does not, then why not presume that other worlds are rejoining with our world to form our future?
Buzz Bloom said:
I looked at the other threads that have discussed retrocausality, ...
My colleagues and I have a book due out in Nov with Oxford UP called "Beyond the Dynamical Universe" in which we argue that many mysteries in physics are due to time-evolved explanation in the dynamical universe and all these mysteries disappear using adynamical explanation in the block universe (our substitute language for retrocausality as Dr Chinese points out). Here is a blurb describing the book http://www.relationalblockworld.com/blog
So, we're hoping it becomes mainstream, but regardless, it is certainly a very powerful explanatory schema as we show.
Likes Ebeb, Jilang and DrChinese
The block universe really is the only way to make sense of relativity. We draw all these pictures of world lines, light cones, and coordinate transformations treating space and time on similar footing. The future exists as much as the past or down or to the side. If we imagine that the future is generated on the fly, then due to relativity of simultaneity, the universe must be specifically generated around me. I think this kind of solipsism is silly.
This is not a valid inference. It could be that "the universe being generated" is not an absolute thing at all, but relative to an observer.
The block universe is a reasonable inference from relativity of simultaneity (see the protracted argument in chapter 2 of the forthcoming book or http://philsci-archive.pitt.edu/3696/ which was published in Space, Time, and Spacetime - Physical and Philosophical Implications of Minkowski's Unification of Space and Time, Petkov (ed.), 2010, Springer). But, we don't have to argue that point here, since we must assume the future already exists in some sense to discuss retrocausality, which is the topic of the thread.
A possible inference, yes. But many discussions of this make the stronger claim that the block universe is required by relativity of simultaneity; this claim is false, as I argue in my Insights article on the topic:
https://www.physicsforums.com/insights/block-universe-refuting-common-argument/
Yes, this I agree with.
Likes akvadrako
and
Exactly. I was just about to complain about that very point.
IMHO, the paragraph quoted is self-contradictory nonsense. o_O
Hi RUTA:
I get from the blurb that the concept is that conceptualizing the universe as a 4D whole without time slices avoids (some?) issues about causality between past and future. What the blurb omitted is any use of the word "causality". I wonder if you might post a brief explanation of how you see this 4D view relating to causality.
Regards,
Buzz
"The following paragraph is a quote from the article that seems to explain the meaning of the authors' idea.
First, to clarify what retrocausality is and isn't: It does not mean that signals can be communicated from the future to the past—such signaling would be forbidden even in a retrocausal theory due to thermodynamic reasons. Instead, retrocausality means that, when an experimenter chooses the measurement setting with which to measure a particle, that decision can influence the properties of that particle (or another particle) in the past, even before the experimenter made their choice. In other words, a decision made in the present can influence something in the past."
1) Compare the rates of expansion now with that at the big bang. Retrocausality assumes that the future already exists and influences the past, so the initial rate of expansion will be different as there is less/more force acting on it.
2) Possibly. Personally I think all aspects of QM make more sense when you consider retrocausality.
That might be true. However, I think that expansion is a free parameter. How would you be able to separate the component of expansion related to the future?
I should note that there are other possibilities for representing the Big Bang in a time symmetric universe. We assume there was something like this, based on the evidence we can see:
Big Bang ----> Present day universe we inhabit ----> Future
There could also have been something like this, in a time symmetric universe, which I acknowledge as purely speculative (but reasonably so if we are considering/assuming time symmetry in the first place):
Anti-future <--- Anti-sub-universe <--- Big Bang ----> Present day sub-universe we inhabit ----> Future
Which would presumably explain why the thermodynamic arrow of time runs in one direction, as we see it. In the anti-future, they too see a single thermodynamic arrow of time - although they are unawares it run counter to ours. This model neatly explains the apparent asymmetry of time. RUTA's relational block world extends in both directions of time. :smile:
Interesting, but which spacetime does the anti-future occupy? Or does it exert an infuence from outside of spacetime? Forgive me, but I am assuming spacetime begins at the big bang? Do you think that our perceived arrow of time is down to entropy and how biological organisms must be required to collect energy from available states to survive disordered states thus giving rise to memory formation time bias?
The Carroll-Chen model works something like this:
https://arxiv.org/abs/hep-th/0410270
In the Carroll-Chen model, the same one. See the paper above.
Likes DrChinese
Nice, thanks! Gives me some good reading (on top of some of RUTA's newest works).
-DrC
Buzz Bloom said:
Hi RUTA:
Regards,
Buzz
In my opinion, causality is a concept relevant only to dynamical explanation. Obviously, the retrocausality camp disagrees, see their "interventionist" account of causality in my Insight https://www.physicsforums.com/insights/retrocausality/. I think it's best to forget that expression when dealing with adynamical explanation in the block universe and merely talk about the 4D patterns. But that's just my preference.
Likes Ebeb
H RUTA:
Thank you for your answer.
Regards,
Buzz
https://arxiv.org/abs/hep-th/0410270In the Carroll-Chen model, the same one. See the paper above.
My only issue with the Carroll-Chen model is that it is pro multiverse. I'm not convinced that spacetime needs or is capable of interacting with states outside of itself. If there has been any test designed to test for parallel/multiple universes I would be interested to read about them but otherwise it is rather speculative at best. If retrocausality is real doesn't it suggest that spacetime can be a self-contained entity?
Not the way you appear to be interpreting the term "multiverse". There is only one spacetime in the Carroll-Chen model. It just happens to contain multiple inflating "bubbles" in a de Sitter background.
Related to A new approach: retrocausality in QFT
1. What is retrocausality in QFT?
Retrocausality in quantum field theory (QFT) refers to the idea that the future can influence the present, in contrast to the usual understanding of causality where the present determines the future.
2. How does retrocausality impact our understanding of causality?
Retrocausality challenges our traditional understanding of causality, where cause always precedes effect. It suggests that future events can have an effect on present events and therefore, the concept of causality may need to be reconsidered.
3. Why is retrocausality important in QFT?
Retrocausality is important in QFT because it provides a possible explanation for some of the strange phenomena observed in quantum mechanics, such as entanglement and the delayed choice quantum eraser experiment. It also has implications for the concept of free will and determinism.
4. How is retrocausality being studied in QFT?
Scientists are studying retrocausality in QFT through theoretical models and experiments. Some theories propose the existence of retrocausal particles, while others suggest a modification of the current understanding of causality. Experimental tests involve observing the effects of future events on present ones.
5. What are the implications of retrocausality for the future of physics?
If retrocausality is proven to be a valid concept in QFT, it could lead to a paradigm shift in our understanding of the fundamental laws of nature. It could also have practical applications in fields such as information processing and communication.
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
10K
  • Quantum Physics
9K
