A Nonlinear Second Order Differential Equation Problem
In summary, the conversation discusses a problem involving a dust particle falling under the influence of gravitational force through water vapor, and developing into a rain droplet. The student is asked to calculate the acceleration of the droplet and determine its equation of motion. After some initial struggles, they are given a hint to use a substitution method to solve the nonlinear second order differential equation. The expert then provides a detailed explanation of the method and solves the equation to find the acceleration and equation of motion for the droplet.
overmage
A Nonlinear Second Order Differential Equation Problem: very frustrating please help!
Hello, I am a first year engineering undergraduate student, and this is my question.
A dust particle of negligible mass starts to fall, t=0, under the influence of gravitational force through mist of saturated water vapor. The vapor condenses onto the dust particle at a constant rate of [tex]\lambda[/tex] kilogram per meter of traveled distance. The dust particle thereby develops into a rain droplet with increasing mass.
a) Calculate the acceleration of the droplet as a function of its velocity and covered distance.
b) Determine the equation of motion of the droplet by integrating the expression of the acceleration, neglecting friction, collisions, etc.
I have already solved a). The equation (which I am told is correct) is:
[tex]\frac{dv}{dt} + \frac{v^{2}}{x} = [/tex] g
where g is the gravitational field strength.
I was given the 'hint' of substituting [tex]f(x) = At^{n}[/tex] to solve this equation for the position x, and determine A and n.
I have no idea how to determine A and n, frankly. In fact, I have never done Second Order ODEs before, let alone nonlinear Second Order ODEs. (Before you ask why I would be set a question on Second Order ODEs not having done it before - my professor - let's just say I've had better elementary schools teachers.)
I arrive at this equation:
(2n[tex]^{2}-n)At^{n-2} = [/tex] g
What do I do from here now? Four hours of rearranging to no avail.
P.S. After sleuthing around, I discovered that the usual method for solving such equations is to substitute it to a first order one. This doesn't look like it...
bump =(
Hi Overmage,
Your equation
[tex]
\frac{dv}{dt} + \frac{v^{2}}{x} = g
[/tex]
is correct, it was a good job to derive it!
Now it is a first order differential equation (contains first derivative only), but non-linear. Luckily, it does not contain the time itself. There is a trick for such equations, often applied in Mechanics: We will use x as independent variable instead of t.
[tex]
\frac{dv}{dt} =\frac{dv}{dx}\frac{dx}{dt}=v\frac{dv}{dx}
[/tex]
Substituting for dv/dt, your equation becomes:
[tex]
\frac{dv}{dx}v+\frac{v^{2}}{x} = g
[/tex]
Now the second trick comes:
[tex]
\frac{dv}{dx}v=0.5\frac{d(v^2)}{dx}
[/tex]
and we choose v^2 as dependent variable, say y=v^2.
Now we arrived at a totally different-looking equation:
[tex]
0.5 \frac{dy}{dx}+\frac{y}{x} = g
[/tex]
This is a linear equation! You can solve it by assuming y in a product form: y=F*G.
Have you learned that method from Maths? If you do not know it yet, I'll explain.
Anyway: the solution will be:
[tex]
v^2=\frac{2gx}{3}
[/tex]
from where you get the acceleration, and it will be a surprise!
ehild
No, I'm not familiar with that. =( could you give me a general idea of how that works out?
You have a differential equation of form
a(x)y'+b(x)y=c(x) (the prime means differentiation), with initial condition y=0 at x=0, the prime means differentiation.
Assume Y=F(X)G(x).
a(x)(F'G+FG')+b(x)FG =c(x). *
You have the freedom to choose G so that
a(x)FG' + b(x) FG =0
Divide the eq. by F.
a(x)G'+b(X)G=0.
You can solve this equation by separating the variables.
[tex] \int{\frac{dG}{G}}=\int{\frac{-b(x)}{a(x)}dx} [/tex]
Replace back G(x) into eq. *.
a(x)F'G(x) = c(x)
[tex]F(x)=\int{\frac{c(x)}{a(x)G(x)}}+const[/tex]
y=F(x)G(x).
Your equation is :
0.5 y' +y/x =g ---> y'+2y/x=2g
a=1, b=2/x, c=g
[tex] \int{\frac{dG}{G}}=-\int{\frac{2}{x}dx} \rightarrow G(x)=x^{-2}[/tex]
[tex] F'G(x)=c(x)\rightarrow F'=2gx^2 \rightarrow
F(x)=\frac{2gx^3}{3}+C[/tex]
[tex]y(x)= F(x)G(x)=\frac{2gx}{3}+\frac{C}{x^2} [/tex]
C=0 according to the initial condition.
[tex]y(x)=\frac{2gx}{3}[/tex]
ehild
Hey,
Thanks a lot for the help! I really appreciate it. However, can i clarify just one last thing:
a=1, b=2/x, c=g
shouldn't c be = 2g?
Thanks for the help you've given! Wow, this problem is kinda hard. Think you've pretty much covered it all though.
overmage said:
Hey,
Yes, of course... :)
ehild
FAQ: A Nonlinear Second Order Differential Equation Problem
What is a nonlinear second order differential equation?
A nonlinear second order differential equation is a mathematical equation that involves the second derivative of an unknown function, and the function itself is not proportional to its derivatives. This means that the equation is not linear, and cannot be solved using traditional methods such as separation of variables or substitution.
Why are nonlinear second order differential equations important?
Nonlinear second order differential equations are important because they are used to model many real-world phenomena, such as population growth, chemical reactions, and electrical circuits. These equations provide a more accurate representation of these systems compared to linear equations, and can help scientists make predictions and understand complex systems.
How do you solve a nonlinear second order differential equation?
There is no one method for solving nonlinear second order differential equations, as it depends on the specific equation and initial conditions. Some techniques that may be used include numerical methods, power series, and perturbation methods. In some cases, it may not be possible to find an exact solution and an approximation must be used.
What are the applications of nonlinear second order differential equations?
Nonlinear second order differential equations have many applications in various fields such as physics, engineering, biology, and economics. For example, they are used to model the motion of a pendulum, the flow of fluids, and the spread of diseases. These equations also play a crucial role in the development of new technologies and solving complex problems.
Are there any limitations or challenges when dealing with nonlinear second order differential equations?
Yes, there are some limitations and challenges when dealing with nonlinear second order differential equations. One major challenge is that there is no general method for solving all types of nonlinear equations, so different techniques must be used for different equations. Additionally, even if an exact solution is found, it may be difficult to interpret and analyze in terms of the real-world system it represents. Numerical methods can also be time-consuming and require high computational power.
