I A = norm-preserving linear map (+other conditions) => A = lin isometry
Shirish
I'm studying "Semi-Riemannian Geometry: The Mathematical Langauge of General Relativity" by Stephen Newman. Theorem 4.4.4 in that book:
Let ##(V,g)## be a scalar product space, and let ##A:V\to V## be a linear map. Then:
  1. If ##A## is a linear isometry, then ##\|A(v)\|=\|v\|\ \forall\ v\in V##
  2. If ##\|A(v)\|=\|v\|\ \forall\ v\in V##, and if ##A## maps spacelike (resp. timelike and lightlike) vectors to spacelike (resp. timelike and lightlike) , then ##A## is a linear isometry.
The proof of part 2 is given like this:
Since ##\|A(v)\|=\|v\|## is equivalent to ##|\langle A(v),A(v)\rangle|=|\langle v,v\rangle|##, the assumption regarding the way ##A## maps vectors yields ##\langle A(v),A(v)\rangle=\langle v,v\rangle##.
Seems a bit incomplete. I'd like to know if my approach is correct:
$$\langle A(v+tw),A(v+tw)\rangle=\langle A(v)+tA(w),A(v)+tA(w)\rangle$$
$$=\langle A(v),A(v)\rangle+t^2\langle A(w),A(w)\rangle+2t\langle A(v),A(w)\rangle=\langle v,v\rangle+t^2\langle w,w\rangle+2t\langle A(v),A(w)\rangle$$
But $$\langle A(v+tw),A(v+tw)\rangle=\langle v+tw,v+tw\rangle=\langle v,v\rangle+t^2\langle w,w\rangle+2t\langle v,w\rangle$$
(I'm not even sure if the ##t## coefficient matters) The above shows that ##\langle v,w\rangle=\langle A(v),A(w)\rangle##.
Is this fine? Secondly, wouldn't this same theorem more generally hold for a linear map ##A:V\to W##, where ##V,W## are both scalar product spaces (regardless of dimensions of ##V## and ##W##)?
The book proof is just a sketch. The point is that without the second condition you could have$$\langle Av, Aw\rangle = -\langle v,w\rangle$$Your proof needs to take this into account.
Yep that I understood already (I mean about why the additional conditions are needed apart from norm preservation), but I was still wondering if the whole theorem holds in more general conditions
Yes, it must. The proof is not dependent on the image space being ##V##.
From
##\langle v+w,v+w\rangle=\langle v,v\rangle+\langle w,w\rangle+2\langle v,w\rangle##
you have
##\langle v,w\rangle = \frac12 \left[\langle v+w,v+w\rangle-\langle v,v\rangle-\langle w,w\rangle \right]##
Thus the inner product of any pair of vectors is determined by inner products of the form ##\langle a,a\rangle##. That is why they didn't write any more.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
