MHB A 'not too challenge' question....
  • Thread starter Thread starter chisigma
    Challenge
The discussion revolves around the sum of the series $\sum_{n=2}^{\infty} \{1-\zeta(n)\}$, where $\zeta(s)$ is the Riemann Zeta Function. The unexpected simplicity of the final result is highlighted, with the calculation showing that the sum equals -1, contrary to initial assumptions. The approach involves interchanging the order of summation and applying the telescoping series technique. Participants emphasize the challenge lies in recognizing the correct result rather than the complexity of the calculations. Ultimately, the conclusion is that the sum of the series is -1.
chisigma
MHB
The challenging aspect to the question is the unexspected semplicity of the final result...
Find the sum of the series...
$\displaystyle \sum_{n=2}^{\infty} \{1-\zeta(n)\}$ (1)
... where...
$\displaystyle \zeta(s)= \sum_{k=1}^{\infty} \frac{1}{k^{s}}$ (2)
... is the Riemann Zeta Function...
Kind regards
$\chi$ $\sigma$
Mathematics news on Phys.org
... where...
Kind regards
$\chi$ $\sigma$
$\displaystyle\sum_{n=2}^{\infty }(1-\zeta(n))=\sum_{n=2}^{\infty }\sum_{k=2}^{\infty }\frac{1}{k^n}=\sum_{k=2}^{\infty }\sum_{n=2}^{\infty }\frac{1}{k^n}=\sum_{k=2}^{\infty }\frac{1}{k^2}(1+\frac{1}{k}+\frac{1}{k^2}+\cdots)=\sum_{k=2}^{\infty }\frac{1}{k^2}\cdot\frac{k}{k-1}=\sum_{k=2}^{\infty }\frac{1}{k(k-1)}=\sum_{k=1}^{\infty }\frac{1}{k(k+1)}=1$, where the last equality it by telescoping:$\displaystyle\sum_{k=1}^{t}\frac{1}{k(k+1)}=\sum_{k=1}^{t}( \frac{1}{k}-\frac{1}{k+1})=\frac{1}{1}-\frac{1}{t+1}\to1$ as $t\to\infty$.
The real 'challenge' was in the fact that the correct result is...
$\displaystyle \sum_{n=2}^{\infty} \{1-\zeta(n)\}= -\sum_{n=2}^{\infty}\sum_{k=2}^{\infty} \frac{1}{k^{n}}=...=-1$
... that isn't 1 of course (Wasntme)...
Kind regards
$\chi$ $\sigma$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
