MHB A Parallel Line Passing Through (-3, 4)
  • Thread starter Thread starter mathdad
The discussion focuses on finding the equation of a line that passes through the point (-3, 4) and is parallel to the y-axis. It is established that a vertical line can be expressed in the form x = k, where k is the x-coordinate of any point on the line. Since the x-coordinate of the given point is -3, the equation of the line is x = -3. This confirms that the line x = -3 is parallel to the y-axis, which is represented by x = 0. The conclusion is that the correct equation for the line is x = -3.
mathdad
1,280
Find an equation of the line that passes through (-3, 4) and is parallel to the y-axis.
The y-axis is the line x = 0.
The equation that passes through the given point must also be a vertical line because it is parallel to the line
x = 0 or the y-axis.
Correct?
Can someone provide a useful hint?
Mathematics news on Phys.org
Correct?
A vertical line can be written in the form:
where $k$ (a real constant) is the $x$-coordinate of every point on the line. :)
$$x=k$$
Give me a second hint.
What is the $x$-coordinate of the given point?
The x-coordinate of the given point is -3.
Is the line x = -3?
Is the line x = -3?
Yes, for any given vertical line, no matter what the $y$-coordinate of a particular point on that line, the $x$-coordinate will be the same throughout. The locus of all points having the same $x$-coordinate is a vertical line. :)
This makes sense. The line x = -3 is // to the line x = 0.
