A particle in a 2d circle with potential
In summary, the conversation discusses the approach to solving for a particle's wavefunction and energy eigenvalues inside a 2D circle with a known potential V(r). The speaker suggests using polar coordinates and solving the time-independent Schrödinger equation with the given boundary conditions. However, the main problem remains in solving the 2nd order differential equation for r with V(r) inside.
Bokul
Hello,
What would be the right approach to solve for a particle's wavefunction/ energy eigenvalues inside of a 2d cicrle with a potential V(r) where r is the radial distance of a particle from the center of the circle? V(r) is known and is some sort of a well potential going to infinity at R (circle's radius) and to 0 at 0.
I'd start to look for the right coordinates according to the given symmetries of the system. It's obvious that for your problem the best choice are plane polar coordinates. Then you write down the time-independent Schrödinger equation (i.e., the eigenvalue problem for the Hamiltonian) in these coordinates and solve for the given boundary conditions.
The good thing with polar coordinates is that the 2D Laplacian separates, i.e., you find the energy eigenfunctions through the ansatz
[tex]\psi(r,\phi)=R(r) \Phi(\phi).[/tex]
Thx, but, I guess, I asked my question too far from its main point. Here what it actually is: once I've applied the separation of variables, I will end up with a 2nd order differential equation for r with V(r) inside of it. And I don't know how to solve it. That is my main problem and, therefore, a question for you.
FAQ: A particle in a 2d circle with potential
What is a particle in a 2d circle with potential?
A particle in a 2D circle with potential refers to a theoretical model in physics where a particle is confined to move in a circular path and is subject to a potential energy function, which determines its behavior and trajectory.
How is the motion of the particle in a 2d circle with potential described?
The motion of the particle in a 2D circle with potential can be described using classical mechanics or quantum mechanics, depending on the scale at which the particle is observed. In classical mechanics, the particle's position and velocity can be determined using Newton's laws of motion. In quantum mechanics, the particle's behavior is described by a wave function.
What factors affect the behavior of a particle in a 2d circle with potential?
The behavior of a particle in a 2D circle with potential is affected by the shape of the potential energy function, the initial conditions of the particle (such as its initial position and velocity), and any external forces acting on the particle.
What is the significance of studying a particle in a 2d circle with potential?
Studying a particle in a 2D circle with potential allows for a better understanding of the fundamental principles of classical and quantum mechanics. It also has practical applications in fields such as engineering, astronomy, and material science.
Can a particle in a 2d circle with potential exist in a real-life scenario?
While the concept of a particle confined to a 2D circle with potential is a theoretical construct, similar systems can be found in nature. For example, electrons in an atom can be thought of as moving in circular orbits around the nucleus, and their behavior is influenced by the potential energy of the atom.
