A A particle locked inside an arrangement of Dirac delta potentials
  • A
  • Thread starter Thread starter hilbert2
    Bound state
hilbert2
Insights Author
TL;DR Summary
Would a dense enough set of point interaction potentials around a particle keep it confined in a limited space?
Suppose I have a 3D polyhedron with a large number of faces, and put a repulsing Dirac delta potential, ##c\delta (\mathbf{x} - \mathbf{x}_i )## with ##c>0## at each vertex point ##\mathbf{x}_i## of the polyhedron. Could this kind of an arrangement of delta potentials keep a particle such as an electron trapped inside that polyhedral surface as a bound state, or would probability density leak out even with a really densely spaced set of Dirac deltas?
Where I got this idea is this recent MIT study about a possibility to keep neutron locked inside a quantum dot, despite it interacting only with the (highly localized) nuclei and not the electrons.
https://pubs.acs.org/doi/10.1021/acsnano.3c12929
A quantum dot is often modelled as a "particle in 2D or 3D box", so I would guess some kind of arrangement of point interaction potentials is how the neutron quantum dot would be described with a theoretical model, but I can't access the full text of that publication yet.
The problem I posed could be investigated with a numerical calculation by approximating the delta functions with sharp gaussian spikes, but that would be less time consuming with an equivalent 2D version.
A delta function already has one bound state.
Yes, but only if it has a negative multiplier in front of it.
Are you saying that if you have a system with a potential of zero everywhere except a number of regions where it is greater than zero, does it have any bound states? It does not.
If you imagine a free particle, with a positive delta function at r = R, and a particle originally in the interior, it will eventually tunnel out. If you want to discuss how long this takes, that depends on the details of R and m. As you would expect, as R gets large (especially with respect to 1/m) the time gets long.
But this gets us into the question of "how almost is almost".
Actually now that makes sense to me, even if a whole spherical surface acts as a delta potential, the particle will escape. Maybe it's a different situation if there's an infinite number of shells at ##r=R##, ##r=2R##, ##r=3R## and so on. Or a 3D lattice with point interactions at each lattice site and an empty vacant space somewhere for the particle to stay in.
Edit: In fact, if you look at Fig. 4 of this article, in a 1D imperfect Kronig-Penney lattice with a larger distance between one of the pairs of neighboring potential energy barriers, a particle seems to have a ground state where it's quite localized inside the largest interval available for it. An equivalent 3D version would probably not necessarily have a bound state, because a particle-in-sphere model with finite potential step (##V(r)=0## when ##r<R## and ##V(r)=V_0## when ##r\geq R##) doesn't have one either if ##V_0## isn't large enough compared to how small the volume of the sphere is.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
