A person slides downa spherical, frictionless surface.
In summary: Ok, so the centripetal force is just mgcos(theta) - Fn. How do you find Fn?Well, I could try solving for Fn, but I think it would be easier to just say what mgcos(theta) is. mgcos(theta) is just the cosine of the angle θ. So, just take the cosine of the angle θ and that will give you Fn. mgcos(theta) = cos(θ)Ok, so Fn is just cos(θ).Now that you have found Fn, can you find the weight force?Yes, by multiplying mgcos(theta) by the weight.mgcos(theta) * weight =
pmd28
64
A person starts from rest at the top of a large, frictionless, spherical surface, and slides into the water below. At what angle θ does the person leave the surface? (Hint: When the person leaves the surface, the normal force is zero.)
Don't Know
I honestly would love to give this an attempt, but I just don't know where to start. It's a problem in my Energy and Power chapter, so I would assume that at the top E(total)=mgh. I just don't know where the angle comes into play. The hint leads me to believe that it would be at an angle of 90 because the entirety of the persons weight force is tangent to the circle, but this answer was wrong.
To get started: Draw the person at an arbitrary angle on the sphere. Set up Newton's 2nd law and see if you can get a relation between the normal force and the speed of the person at that point. (Energy will come in later.)
Ok I drew him at the top, therefore he has to be at rest. And I have the normal force and weight force acting on him
The top is too special. You want a general relation between the normal force and the speed. So, think about an arbitrary point at some angle θ from the vertical.
pmd28 said:
A person starts from rest at the top of a large, frictionless, spherical surface.
That's what the question says.
Yes, but he doesn't stay at the top. We need to know what happens as he slides down along the surface.
Oh, ok. So I'll just pick 60 degrees then. So there is the Normal force and two compnents of the weight force.
We don't want to favor any particular angle. Work with symbols and let θ denote any (unspecified) value of the angle. Likewise, just let v represent the speed at that point.
The problem gives you a hint that you should consider the magnitude of the normal force. Is there a way to get an expression for the normal force in terms of the angle θ and the speed v?
Well I'm thinking centripital acceleration ac=v^2/r. And as far as theta, y=r-rcos(theta), where theta is subtended between r and y. I'm still not sure where the Normal force fits in.
Great!
How do you relate forces to acceleration?
F=m(v^2/r)
How would you write out the left side of the equation in terms of all of the forces acting on the guy?
OH wait, would the point where he falls off be where Fc=Weight Force? And KE + PE @ the moment he falls off equals the PE at the start point. Then i can solve for v^2 relate that to the weight force which in this case would mgCos(theta)
No, let's let the equations tell us the answer. When you write down the million dollar equation, F = m(v^2/r), what does F represent?
Centripital force?
Oh, sorry. I think you might actually have it. When you first said "weight force" I was thinking mg. But later you said "weight force" is mgcos(theta), so you were actually thinking about the component of the weight acting toward the center of the sphere. That's right. So, Sounds good to me, now. Work it out and see what you get.
Yea it came out right. Thanks. There's another probelm I'm stumped on, you think you could help. I'm going to make it into a new thread.
"Centripetal force" is just the name we give to the net force acting toward the center of the sphere. It's always due to whatever physical forces are acting on the object. You have identified mgcos(theta) as acting toward the center. Should you also include the normal force as contributing to the centripetal force?
No, because the normal force acts on the slider away from the center of the circle, while the centripital force acts on the slider towards the center of the circle
Acting away from the center is like acting negatively toward the center. So, while sliding down, the centripetal force would be mgcos(theta) - Fn where Fn is the normal force. But you are looking for the place where he just leaves the surface, and that's where Fn = 0 as stated in the hint.
Related to A person slides downa spherical, frictionless surface.
1. How does friction affect a person sliding down a spherical surface?
Friction does not play a role in this scenario as the surface is assumed to be frictionless. This means that there is no resistance to the person's motion and they will continue to slide without slowing down.
2. What is the force that causes a person to slide down a spherical surface?
The force that causes a person to slide down a spherical surface is gravity. This force pulls the person towards the center of the sphere, causing them to accelerate downwards.
3. How does the angle of the surface affect a person's speed while sliding?
The angle of the surface does not affect the person's speed while sliding. As long as the surface is frictionless, the person will slide at a constant speed regardless of the angle of the surface.
4. Will the person's mass affect their speed while sliding down a spherical surface?
The person's mass will not affect their speed while sliding down a spherical surface. According to Newton's Second Law of Motion, the acceleration of an object is directly proportional to the force applied to it and inversely proportional to its mass. Since the force (gravity) is constant and the mass of the person does not change, their speed will also remain constant.
5. Can a person change their direction while sliding down a spherical surface?
Yes, a person can change their direction while sliding down a spherical surface by using their arms and legs to push against the surface. This will cause a change in their momentum and alter their direction of motion.
