Insights A Physics Misconception with Gauss’ Law
Gauss' Law is often misunderstood, particularly when transitioning from lower to upper-level electromagnetism courses. A common misconception arises when students incorrectly apply Gauss' Law to systems lacking spherical symmetry, leading to erroneous conclusions about electric fields. The discussion highlights the importance of recognizing the limitations of Gauss' Law and emphasizes the need for a solid understanding of vector calculus to properly grasp electromagnetic concepts. Many students struggle with these complexities due to oversimplified teaching methods that can hinder their learning. Addressing these misconceptions can significantly aid students in mastering electromagnetism.
Orodruin
Staff Emeritus
Insights Author
2024 Award
Likes topsquark, bhobba, vanhees71 and 3 others
Orodruin said:
I kid you not. After doing very well in lower level undergrad physics I moved onto the Griffiths level class and I got a 1/30 on the first test because I applied Gauss’ Law to circular ring with linear charge density proportional to ## /cos /theta ##. Find the field on the axis. And since ##/cos /theta## evaluates to ##0## when integrated over ##\left[ 0, 2 \pi \right] ## I thought the field was also ##0##.
I really thought at the the time that Gauss’ Law was all that I needed to know. I asked my professor if the grade was a mistake and he said “no your performance was truly dismal”.
I ended up retaking the class and studied my ass off by doing damn near every problem in the first 7-8 chapters and ended up earning his respect “I saw how hard you worked and I am very pleased with your progress”.
Realizing the limitations of Gauss’ Law might be trivial for those who have had years of experience but it’s a huge stumbling block for a lot of people (not just me) making the jump from lower level E&M to upper level E&M so I’m sure some younger students will benefit greatly from this article.
Likes Chikitai, bhobba, Delta2 and 4 others
This is the hope. I have seen this kind of error ”more than once” here at PF.
Likes bhobba, vanhees71 and PhDeezNutz
So I’m not alone!
Likes bhobba and vanhees71
You are not, and in my opinion it's the result of some well-meaning didadictics to "simplify" but making the subject in fact more complicated. There is some unfortunate idea in the didactics community that "math is too difficult". Of course, it's some effort to learn the math, and here it's vector calculus, which is a lot of material, but at the end it makes the physics more easy to formulate: The Maxwell equations in their "local form", i.e., as differential equations are the fundamental equations. The integral form can be easily derived from them when needed, and usually they are "more complicated" than the "local form".
Likes bhobba, BvU, PhDeezNutz and 2 others
Excellent thread.
Thanks
Bill
I'm working through something and want to make sure I understand the physics. In a system with three wave components at 120° phase separation, the total energy calculation depends on how we treat them: If coherent (add amplitudes first, then square): E = (A₁ + A₂ + A₃)² = 0 If independent (square each, then add): E = A₁² + A₂² + A₃² = 3/2 = constant In three-phase electrical systems, we treat the phases as independent — total power is sum of individual powers. In light interference...
  • · Replies 83 ·
  • · Replies 30 ·
  • Sticky
  • · Replies 0 ·
