A point mass inside a spherical shell
In summary, the book discusses the concept of potential energy within a spherical shell, stating that it is constant and does not depend on the position within the shell. This leads to the conclusion that the force on a point mass inside the shell must be zero. However, the book later expands on this concept and states that in any spherical mass distribution, the force on a point mass can be calculated by removing all the mass at points farther than the point's distance from the center. This is not a contradiction, as the earlier result only applies to spherical shells, while the latter applies to any spherical mass distribution.
amiras
65
I am having some difficulties understanding something here, it seems to me that the book at some point deny itself or I clearly do not get it.
So it firstly states that:
Inside the spherical shell the potential energy does not depend on radius from the center of the shell to the point of mass m and has the same value everywhere inside the shell.
So the potential energy between the spherical shell and the point mass m is:
U = -GMm/R, where M is the mass of the shell, and m - mass of a point mass inside the shell, R is the radius of the shell. So clearly this potential energy does not depend on where it is inside the shell and is always constant.
Since the force is the negative gradient of the potential energy function, and U=const. the Force must be zero (everywhere inside the shell?)
But now the book says:
More generally, at any point in the interior of any spherical symmetric(radius R) mass distribution, at a distance r from its center, the gravitational force on a point mass m is the same as though we removed all the mass at points farther than r from the center and concentrated all the remaining mass at the center.
So now it states that the force is not zero and can be calculated. First it said that the force on m at any point inside the shell must be zero. What am I missing here?
That is correct. This was proven by Newton in his Shell Theorem.
If you would read this part carefully, it is not referring to just spherical shells but any spherical mass distribution, thus there is no contradiction. In fact, this statement is a rewording of the Shell Theorem, because we can consider any spherical mass distribution to be composed out of many spherical shells. That we can "remove all the mass at points farther than r from the center" is a consequence of the earlier result that the force on the point mass due to these outer spherical shells is zero because the point mass lies within these shells!
Yes
There's no contradiction. The second case is not just a shell: there can also be mass within the radius r. Consider a solid sphere of radius R. If we have a point mass at radius r from the centre, we can imagine the sphere divided into two parts:
1. A sphere of radius r
2. A spherical shell of inner radius r and outer radius R
The gravitational force of the sphere of radius r on the point mass is the same as if all its mass were concentrated at its centre. The gravitational force of the remaining shell on the point mass is zero.
No, this also gives zero in the case of your example with the massive shell. :-)
Thank you for your explanation, all this starts to make sense to me now! Thanks :)
Related to A point mass inside a spherical shell
What is a point mass inside a spherical shell?
A point mass inside a spherical shell is a hypothetical scenario in which a mass is placed at the center of a hollow spherical shell, with no other forces acting on it.
What is the gravitational force on a point mass inside a spherical shell?
According to Newton's law of gravitation, the gravitational force on a point mass inside a spherical shell is zero, as the mass is equally attracted to all points on the shell and the forces cancel out.
Why does a point mass inside a spherical shell experience no net force?
A point mass inside a spherical shell experiences no net force because the gravitational forces from all points on the shell are equal in magnitude and opposite in direction, resulting in a canceling out of forces.
How does the distance between the point mass and the shell affect the gravitational force?
The distance between the point mass and the spherical shell does not affect the gravitational force, as the force is solely dependent on the mass of the shell and the point mass, and not their distance apart.
What is the significance of a point mass inside a spherical shell in physics?
The concept of a point mass inside a spherical shell is used in physics to understand the principles of gravity and to simplify complex gravitational systems. It also helps to explain the lack of gravitational force inside a hollow spherical planet, such as Earth.
  • Classical Physics
