A probability of field amplitude in QFT
In summary, "A probability of field amplitude in QFT" explores the concept of field amplitudes within Quantum Field Theory (QFT) and how these amplitudes relate to the probabilistic interpretation of quantum states. It emphasizes the role of field amplitudes in describing particle interactions and the calculation of transition probabilities. The paper discusses the mathematical framework used to quantify these amplitudes and their implications for experimental predictions, highlighting the significance of understanding field amplitudes for advancing theoretical physics and experimental validation.
MichPod
231
45
TL;DR Summary
get a probability density for a quantum field
Per quantized scalar field (quantized Klein-Gordon equation), suppose we act on a vacuum state |0> with some set of creation operators to have some particles.
How then can we calculate a probability density for the field to have a particular value ##\psi_0## (upon measurement) at a specific point (t, x, y, z)?
I am interested in understanding a general formula and approach, not in making a specific calculation in all the details.
The question doesn't make sense. To get a meaningful probability density, you need to pick an observable. The field is not an observable.
Why the field is not observable? (I expected the value of the field is observable because it is observable in a classical case).
Just to be on the same page, we can observe a coordinate of a quantum harmonic oscillator at a specific moment of time, right? By analogy, I though, we can observe an amplitude of a field at a particular time and coordinate.
Likes vanhees71 and Delta2
Because it's not a Hermitian operator.
You expected wrong. A quantum field is not at all the same kind of thing as a classical field.
What Hermitian operator corresponds to this observable?
There is no such analogy for a quantum field.
For a harmonic oscillator? Per Schrodinger picture, it is just 'x'.
How can I see that the field operator is not Hermitian? I though it is for the case of K-G equation.
In the position representation, yes. But this observable is position--the "position of the oscillator" (which is viewed in this representation as a point particle oscillating around in a particular potential). It is not "wave amplitude" or "field amplitude".
I expected there is an obvious analogy between the x coordinate of an oscillator and the value of a quantum field at particular point. Why was I wrong?
BTW, how can I see that the field operator is not Hermitian, as you said? I though it is for the case of K-G equation.
To continue, as a discrete approximation we can model a K-G field with some mattress of discrete particles connected with springs. Acting with creation operators on the vacuum (ground) state of that mattress would correspond to adding phonons to the "lattice" of mattress. So I think that asking for a probability density of a particular particle of the mattress to have particular displacement at a particular time should be very well posed and make sense. This should also make sense for a continuous limit when we pass from the mattress to a continuous quantized K-G field and want to measure a value of the field at a particular point.
Why would you expect not to be wrong? You're just making a hand-waving analogy. You haven't given any references, so I don't know where your hand-waving analogy is coming from.
A quantum field is an operator; it doesn't even have a "value at a particular point", much less one that is analogous to the x coordinate of an oscillator.
What is the field operator for the K-G equation?
Ok.
Ok.
Whether it makes sense or not, it is irrelevant as far as using this toy model as a heuristic for quantum field theory is concerned. The analogue of the quantum field for this toy model is the creation and annihilation operators, not the particles or their positions. The whole toy model itself is not a toy model of a distribution of quantum fields in a region of spacetime; it is a toy model of a quantum field at a single point of spacetime. A toy model of a quantum field theory in a region of spacetime will have one of these mattresses at every point.
Even if the K-G operator turns out to be Hermitian, that does not mean quantum field operators in general are.
PeterDonis said:
Is this operator Hermitian? Are all of its eigenvalues real?
Providing the Hermitian conjugation of ##\hat{a}## is ##\hat{a}^\dagger##, this operator is Hermitian (self-adjoint)
Likes vanhees71
So if that is the case, what is its physical meaning? What are the eigenstates and eigenvalues of this operator?
AFAIK, phonons do not describe vibrations of the individual particles of the "mattress", but rather are modes of vibration of the entire collective of the particles, i.e., the entire "mattress."
Likes Nugatory, mattt and vanhees71
Yes, that's correct.
Likes Hill
Agree. And I did not mean anything opposite. The mattress has some physical particles connected with springs, then phonons correspond to the modes of the vibration of the mattress as a whole.
Likes vanhees71 and Hill
Of course in principle a neutral-Klein-Gordon field operator may represent an observable, i.e., it's a self-adjoint operator, fulfilling the microcausality condition. So they can represent, at least formally, local observables. I only do not have a concrete simple physical example for it.
Likes MichPod
Thank you. Thank you for confirming my question has some sense.
Note, though, that the "neutral" (i.e., uncharged) is key. A charged Klein-Gordon field operator is no longer self-adjoint. Nor is a fermionic field operator (only fermionic bilinears like ##\bar{\psi} \psi## are). I'm not sure about an uncharged spin-1 (Maxwell) field operator.
That is why I asked the OP about the physical meaning of the operator in post #15.
All along we've been talking about a free Klein-Gordon field operator. However, I'm not sure this still holds for an interacting Klein-Gordon field operator.
Likes vanhees71
Fields corresponding to uncharged particles, such as electromagnetic field and Higgs field, are hermitian, so these fields are observables. This fact does not depend on whether the fields are free or interacting. Even if one considers a non-hermitian field, such as electron field ##\psi##, one can always construct a hermitian field ##\phi= \psi+\psi^{\dagger}##.
Likes vanhees71
In gauge theories there's the additional caveat that only gauge-invariant (composite) local field self-adjoint operators can represent local observables.
FAQ: A probability of field amplitude in QFT
What is the field amplitude in Quantum Field Theory (QFT)?
In Quantum Field Theory, the field amplitude typically refers to the value of a quantum field at a specific point in space and time. It is a fundamental concept that represents the strength or intensity of the field at that point. The field amplitude can be quantized, leading to the creation and annihilation operators that describe particles and their interactions.
How is the probability of field amplitude calculated in QFT?
The probability of a specific field amplitude in QFT is calculated using the path integral formulation. This involves integrating over all possible field configurations, weighted by the exponential of the action (in natural units, the action is divided by Planck’s constant). The probability density for a particular field amplitude is given by the square of the absolute value of the wave functional.
What role does the path integral play in determining field amplitude probabilities?
The path integral is central to determining field amplitude probabilities in QFT. It sums over all possible field configurations, allowing for the calculation of transition amplitudes and correlation functions. This integral takes into account all possible histories of the field, providing a comprehensive framework for understanding quantum phenomena.
How do creation and annihilation operators relate to field amplitudes in QFT?
Creation and annihilation operators are mathematical constructs in QFT that add or remove quanta (particles) from the field, respectively. They are directly related to the field amplitudes, as these operators act on the quantum states to change the number of particles. The field operators can be expressed in terms of these creation and annihilation operators, linking them to the underlying field amplitudes.
Can field amplitude probabilities be directly measured in experiments?
Field amplitude probabilities themselves are not directly measurable; instead, what can be measured are the outcomes of experiments that depend on these probabilities, such as particle scattering events, decay rates, and cross-sections. These measurable quantities are calculated using the probabilities derived from the field amplitudes within the framework of QFT.
