Why Does MCNP5 Fail with 100 Million NPS and 35 Threads?
  • Thread starter wangm23456
  • Tags
    Mcnp5
In summary, setting nps to 50000000 and using 35 threads may result in a more stable and efficient process.
wangm23456
when I set nps=100000000 and 35 threads , there is a problem that cpu are always 100% but the process of mcnp stays at 20000000 ; But if I set nps=50000000 and 35 threads , there will be normal.
Anyone knows why?
This could be due to the fact that the system is not able to handle the load of 100000000 nps with 35 threads. It is possible that your system does not have enough resources (such as memory, disk space, etc) to properly handle this amount of data. Additionally, some systems may also have limits on how many threads can be used at once, so increasing the number of threads may be causing too much strain on the system. It is best to experiment with different values for nps and threads to determine what works best for your system.
Related to Why Does MCNP5 Fail with 100 Million NPS and 35 Threads?
1. What is MCNP5 with mpi?
MCNP5 with mpi is a widely used Monte Carlo simulation software developed by Los Alamos National Laboratory. It is used to simulate and analyze the transport of particles and radiation in various materials and geometries.
2. What is the main problem with MCNP5 with mpi?
The main problem with MCNP5 with mpi is that it can be difficult to set up and run, especially for new users. It requires a good understanding of the underlying physics and parameters in order to obtain accurate results.
3. How does mpi affect MCNP5 simulations?
MPI (Message Passing Interface) is a communication protocol that allows multiple processors to work together and solve a large problem in parallel. In the case of MCNP5, using mpi can significantly reduce the simulation time by distributing the workload among multiple processors.
4. What are some common errors encountered when using MCNP5 with mpi?
Some common errors when using MCNP5 with mpi include issues with input file formatting, incorrect input parameters, and problems with mpi libraries or configurations. It is important to carefully check and troubleshoot these potential errors in order to successfully run the simulation.
5. Are there any resources available for troubleshooting MCNP5 with mpi?
Yes, there are various online resources and forums where users can seek help and troubleshoot issues with MCNP5 with mpi. Additionally, the software developers provide technical support and documentation for users to reference and address any problems they may encounter.
  • Feedback and Announcements
  • Biology and Medical
  • Mechanical Engineering
  • Astronomy and Astrophysics
  • DIY Projects
