- 2,136
- 2,708
In any triangle ABC, prove that $$a^2 b^2 c^2 \left (\sin {2A} +\sin {2B} + \sin {2C} \right) = 32 \Delta ^3$$
Here ##\Delta ## means the area of the triangle.
Wrichik Basu said:Homework Statement
Here ##\Delta ## means the area of the triangle.Homework Equations
Buffu said:This thread is marked solved. why ? did you worked this out or you still need help ?
Wrichik Basu said:I worked it out with help from another website where I posted it.
https://math.stackexchange.com/ques...em-in-trigonometry-properties-of-triangles-v2
Buffu said:Then it is bad of you to cross post on multiple sites.
Wrichik Basu said:Of course I'll cross post, because previously by doing this, several times I've got several different correct ways to solve a single problem, which is interesting.
The properties of a triangle in trigonometry include the Pythagorean theorem, which states that in a right triangle, the square of the length of the hypotenuse is equal to the sum of the squares of the other two sides. Additionally, there are the sine, cosine, and tangent ratios, which relate the sides and angles of a triangle.
To use the sine, cosine, and tangent ratios, you must identify which sides and angles are known and which are unknown. Then, you can use the appropriate ratio (sin = opposite/hypotenuse, cos = adjacent/hypotenuse, tan = opposite/adjacent) and solve for the unknown side or angle using basic algebra.
The Law of Sines states that in any triangle, the ratio of the length of a side to the sine of the angle opposite that side is constant for all sides and angles in the triangle. This can be used to solve for missing sides and angles in non-right triangles.
The Law of Sines is used to solve for missing sides and angles in any triangle, while the Law of Cosines is specifically used for solving for the third side of a triangle when the other two sides and the included angle are known. It can also be used to solve for missing angles in a triangle.
Trigonometry and triangle properties have many real-life applications, such as in navigation, engineering, architecture, and astronomy. They are used to calculate distances, heights, and angles in various fields and industries. For example, triangulation is a common method used in surveying and GPS navigation to determine the location of a point based on the angles and distances to known points.
