A problem involving thin film interference
The discussion focuses on the phase changes that occur during thin film interference when light transitions between media of different refractive indices. It explains that a phase change of λ/2 occurs at both the air-plate and plate-glass interfaces, leading to a cancellation of phase changes and establishing the condition for constructive interference. The derived formula for the minimum non-zero thickness of the film is t = λ/(2n_F). In a reversed scenario, where no phase change occurs at the interfaces, the same condition for constructive interference applies, confirming the consistency of the reasoning. Overall, the reasoning presented is validated as correct.
lorenz0
A blue (##\lambda=450nm##) beam of light hits a glass plate with ##n_g=1.5##. Calculate the minimum thickness that a plate with refractive index ##n_F=1.33##, that must be placed between the air and the glass to produce the maximum intensity reflected in the blue, should have. How much would this thickness have to be if the light was coming from the glass towards the air?
##\lambda_{medium}=\frac{\lambda}{n_{medium}}##
I know that every time that light goes from traveling through a medium with lower refractive index to one with a higher refractive index the reflected light undergoes a ##\frac{\lambda}{2}## phase change. Since this happens both at the air-plate and plate-glass interfaces we have that the phase changes cancel each other out and the condition for constructive interference is (where ##t## denotes the thickness of the plate): ##2t=m \lambda_{plate}\Leftrightarrow 2t=m\frac{\lambda}{n_F}\Leftrightarrow t=\frac{m\lambda}{2n_F}## so the minimum (non-zero) thickness is ##t=\frac{\lambda}{2n_F}.##
In the second scenario the situation is reversed and there is no ##\frac{\lambda}{2}## phase change for both the glass-plate interface and the plate-air interface and so the condition for constructive interference again reads ##2t=m \lambda_{plate}## and we get the same result as before.
Is this correct? I still have to fully grasp this phenomenon and I would like to have feedback on the way I have reasoned about this problem, thanks.
Your reasoning is correct.
Likes lorenz0 and Charles Link
Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
