A problem with significant figures
In summary, the surface area of a cube with a side length of 12.04 cm is 869.8 cm^2 when rounded to four significant figures. The numbers in the formula should be treated as exact values, so the answer should not be further rounded down to 900 cm^2.
Richlair
The side of a cube is 12.04 cm. Write it's surface area rounded off to the appropriate significant figures.
Surface area=6 x side^2
For multiplying, the answer should be written with the number of significant figures equal to the least number of significant available in the numbers in the product.
Upon multiplying, the actual answer is 869.7696. In my book, it was given that since 12.04 has four significant figures, we must round off 869.7696 to four significant figures and hence, the answer is 869.8.
My doubt is that, since there is a 6 present in the product that has only one significant number, the answer should be expressed with only one significant number and so, the answer should be 900. Am I right in saying that?
The 6 in the formula is exact and should be treated like a mathematical constant known to infinite significant figures.
Dickfore is correct. The same applies to the 2 in the s2 that you used to find the area and the half in A=[itex]\frac{1}{2}[/itex]bh.
The question has already been answered, but I thought I'd just throw down one more point.
How many sides of a cube are there?
6.
That's easy.
But, we could be even more precise and say that there are 6.000000000000000000 sides. Since we know the exact value here, it's irrelevant how many digits there are. We normally just use as many significant figures as necessary.
As a scientist, it is important to understand the rules for significant figures and how to properly round off numbers. In this case, the side of the cube is given with four significant figures, so the surface area should also be expressed with four significant figures. Therefore, the correct answer is 869.8 cm^2, as given in your book.
Your doubt about rounding to one significant figure is not correct. When multiplying or dividing numbers, the answer should have the same number of significant figures as the number with the least number of significant figures in the calculation. In this case, that number is 12.04, which has four significant figures. Therefore, the answer should also have four significant figures.
It is also important to note that significant figures represent the accuracy of a measurement or calculation, not the precision. In this case, the side of the cube is given to the hundredths place (12.04 cm), so the surface area should also be expressed to the hundredths place (869.8 cm^2). Rounding to the nearest hundred (900 cm^2) would result in a less accurate answer.
In summary, the surface area of the cube should be expressed with four significant figures (869.8 cm^2) to accurately represent the precision of the given measurement.
FAQ: A problem with significant figures
What are significant figures?
Significant figures are the digits used to represent a measurement or calculation. They include all the known digits and one estimated digit.
Why are significant figures important?
Significant figures are important because they help us understand the precision or accuracy of a measurement or calculation. They also help us avoid misleading or incorrect results.
What is a problem with significant figures?
A problem with significant figures occurs when there is uncertainty or inconsistency in the measurement or calculation, leading to incorrect or misleading results.
How do you determine the number of significant figures in a measurement?
The number of significant figures in a measurement is determined by counting all the known digits and the estimated digit. Non-zero digits and zeros between non-zero digits are significant, while leading and trailing zeros may or may not be significant depending on the context.
How do you handle significant figures in calculations?
In calculations, the result should have the same number of significant figures as the measurement with the least number of significant figures. Intermediate calculations should be carried out to one more significant figure than the least precise measurement to avoid rounding errors.
