A property of solution of ODE y''+p(x)y=0
In summary, we have an ODE $y''+p(x)y=0$ with $p$ being continuous on $\mathbb{R}$ and $p(x)\leq 0$ for all $x\in\mathbb{R}$. We are given that $f$ is a solution defined on $[a,+\infty)$ with $f(a)>0$ and $f'(a)>0$. We need to prove that $f(x)>0$ for all $x\in[a,\infty)$. Using the ODE $y''=-p(x)y$, we can see that if $p(x)\leq 0$, $y(a)>0$, and $y'(a)>
ipaper
Let $f$ be a solution of the following equation $y''+p(x)y=0$, $p$ is continuous on $\mathbb{R}$ such that $p(x)\leq 0$ for all $x\in\mathbb{R}$. Suppose that $f$ is defined on $[a,+\infty)$, $f(a)>0$, $f'(a)>0$, $a\in\mathbb{R}$ .
Prove $f(x)>0$ for all $x\in[a,\infty)$.
Any help would be appreciated.
Welcome on MHB ipaper!...
... writing the ODE as...
$\displaystyle y^{\ ''} = - p(x)\ y\ (1)$
... if $p(x) \le 0, \forall x \in \mathbb{R}$, $y(a)>0$ and $y^{\ '}(a)>0$, then y(x) must be a non decreasing function in $[a, + \infty)$ and therefore it will be $y(x)> 0\ \forall x \in [a, + \infty)$ ...
Kind regards
$\chi$ $\sigma$
Would you please tell me more specifically? I haven't got the picture.
All right!... writing again the ODE...
... let's suppose $p(x) \le 0, y(a)>0, y^{\ '}(a)>0$... that means that for x=a y, y' are positive and y'' non negative... that means that for $x= a + \varepsilon$ it will be $y(a + \varepsilon) > y(a)$ and that is true for all $\varepsilon$, so that y will be a non decreasing function and that means that it will be $y(x) > 0$ for all x in $[a, + \infty)$...
Kind regards
$\chi$ $\sigma$
FAQ: A property of solution of ODE y''+p(x)y=0
1. What is the general form of a solution to the ODE y''+p(x)y=0?
The general form of a solution to this ODE is y(x) = Ae∫p(x)dx + Be-∫p(x)dx, where A and B are constants.
2. How do you determine the particular solution to the ODE y''+p(x)y=0?
The particular solution can be determined by using initial or boundary conditions, such as known values of y and its derivatives at a specific point.
3. Can the ODE y''+p(x)y=0 be solved analytically?
Yes, the ODE can be solved analytically using the general form of the solution and specific initial or boundary conditions.
4. What does the p(x) term represent in the ODE y''+p(x)y=0?
The p(x) term represents the coefficient of the first derivative of y with respect to x. It can also be thought of as the rate of change of the slope of the solution curve at a given point.
5. Are there any real-world applications of the ODE y''+p(x)y=0?
Yes, this ODE has many applications in physics and engineering, such as modeling the motion of a pendulum, the behavior of a spring-mass system, and the decay of radioactive substances.
