MHB A quadrilateral inscribed in a semicircle
  • Thread starter Thread starter anemone
    Inscribed
In the discussion, a proof is presented for the equation relating the sides of a quadrilateral inscribed in a semicircle, specifically showing that \(x^3 - (a^2 + b^2 + c^2)x - 2abc = 0\), where \(x\) is the diameter and \(a\), \(b\), and \(c\) are the lengths of the sides. The proof utilizes trigonometric identities, particularly the sine and cosine functions of angles formed at the center of the semicircle. By expressing the sine values in terms of the sides and substituting them into the equation, the relationship is established. The angles at the center sum to \(\pi/2\), leading to a simplification that confirms the derived equation. This mathematical relationship highlights the geometric properties of quadrilaterals inscribed in semicircles.
anemone
MHB
POTW Director
Let $PQRS$ be a quadrilateral inscribed in a semicircle with diameter $PS=x$. If $PQ=a$, $QR=b$, $RS=c$, then prove that $x^3-(a^2+b^2+c^2)x-2abc=0$.
Mathematics news on Phys.org
[sp]
Denote the angles at $O$ as $2\alpha$, $2\beta$, $2\gamma$, as in the diagram. Note that $\sin\alpha = \dfrac{a/2}{x/2} = \dfrac ax$, and similarly $\sin\beta = \dfrac bx$, $\sin\gamma = \dfrac cx.$ Also, $\alpha + \beta + \gamma = \pi/2$, so that $\sin\alpha = \cos(\beta + \gamma) = \cos\beta\cos\gamma - \sin\beta \sin\gamma$. Hence $\cos\beta\cos\gamma = \sin\alpha +\sin\beta \sin\gamma$, and similarly $\cos\alpha\cos\gamma = \sin\beta +\sin\alpha \sin\gamma$. Then $$\begin{aligned}1 = \sin(\alpha+\beta+\gamma) &= \sin(\alpha+\beta)\cos\gamma + \cos(\alpha+\beta)\sin\gamma \\ &= \sin\alpha\cos\beta\cos\gamma + \cos\alpha\sin\beta\cos\gamma + \sin^2\gamma \\ &= \sin\alpha(\sin\alpha + \sin\beta\sin\gamma) + \sin\beta(\sin\beta + \sin\alpha\sin\gamma) + \sin^2\gamma \\ &= \sin^2\alpha + \sin^2\beta + \sin^2\gamma + 2\sin\alpha\sin\beta\sin\gamma. \end{aligned}$$ Now all you have to do is to substitute the values $\sin\alpha = \dfrac ax$, $\sin\beta = \dfrac bx$, $\sin\gamma = \dfrac cx$ to get $1 = \dfrac{a^2}{x^2} + \dfrac{b^2}{x^2} + \dfrac{c^2}{x^2} + 2\dfrac{abc}{x^3}$, from which $x^3 = (a^2 + b^2 + c^2)x + 2abc.$[/sp]
Opalg said:
[sp]
Thank you Opalg for participating!
My solution:
From the Ptolemy Theorem, we have the product of diagonals equals the sum of the products of the opposite sides for any cyclic quadrilateral.
So, in our case, we have the following identity from the Ptolemy Theorem:
$PR \cdot QS=ac+bx$---(1)
In order to get rid of the variables $PR$ and $QS$, we have to relate them to the variables $a, b, c, x$ and this can be done by observing there are two right-angle triangles exist in the diagram since PS is the diameter of the cicle, so by applying the Pythagoras' Theorem to each of these triangles we get:
$PR^2=x^2-c^2$ and $QS^2=x^2-a^2$
Hence, raise the equation (1) to the second power and replace the two equations above into it gives
$PR^2 \cdot QS^2=a^2c^2+b^2x^2+2abcx$
$(x^2-c^2)(x^2-a^2)=a^2c^2+b^2x^2+2abcx$
$x^4-a^2x^2-c^2x^2+\cancel{a^2c^2}=\cancel{a^2c^2}+b^2x^2+2abcx$
$x^4-a^2x^2-c^2x^2=b^2x^2+2abcx$
$x^4-(a^2+b^2+c^2)x^2-2abcx=0$
$\therefore x^3-(a^2+b^2+c^2)x-2abc=0$ since $x\ne 0$ and we're done.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
