A question about Greatest common factor (GCF) ?
  • B
  • Thread starter awholenumber
In summary, the conversation discusses the concept of finding the Greatest Common Factor (GCF) and the Least Common Multiple (LCM) of two numbers. It is mentioned that the GCF involves prime factorization of the numbers, but there are also efficient algorithms such as Euclid's algorithm that can be used. The relationship between GCF and LCM is also explained, with the formula LCM(a,b) = a*b/GCF(a,b). It is noted that prime factorization is just one way to find the GCF, and different algorithms can be more efficient, such as binary GCD or Euclidean_algorithm.
awholenumber
200
When we try to find the Greatest common factor (GCF) of two numbers , does it only involve prime factorization ?
:nb)
Mathematics news on Phys.org
Yes. The GCF is a product of primes but is not usually a prime itself. Prime factorization of both numbers is the way to find out what the GCF is. If you have the prime factorization of both numbers, it is easy to calculate the GCF.
Ok , so the same prime factorization is used to find the LCM too , right ?
Yes.
Ok , Thanks
I dare to disagree, Euclid's algorithm or binary GCD are used to find GCD, then LCM(a, b)=a*b/GCD(a, b).
Likes FactChecker
I stand corrected. I was not familiar with these algorithms. The binary GCD algorithm and Euclidean_algorithm are interesting.
Ok, i have one more doubt .
The GCF of two numbers involves prime factorization of those two numbers , then multiply those factors both numbers have in common
Isnt LCM about finding the least common multiple of two numbers ?
What does that have anything to do with prime numbers ?
You can find the LCM via LCM(a, b)=a*b/GCD(a, b), if you have the GCD first.
That is often the most practical way to find the LCM.
Prime factorization is just one possible way to find the GCD. For large numbers, it can be very time-consuming, and different algorithms can be more efficient.
Thanks for the information mfb , i am just trying to cover the algebra 1 for dummies book .
It doesn't have a method like this LCM(a, b)=a*b/GCD(a, b) mentioned in it .
You'll find that in an "algebra for intelligent students" textbook!
Likes MAGNIBORO
lol ok , first let me somehow finish this one book properly :wink:
It's still worth understanding why the two are related. The basic argument is:
##a = a'g, b = b'g##
Where ##g## is the GCD of ##a## and ##b## and ##a', b'## are how much bigger ##a## and ##b## are than ##g##.
For example: if ##a = 42## and ##b = 15##, then ##g = 3## and ##a=14 \times 3, b = 5 \times 3##, hence ##a' = 14, b' = 5##
Now, the LCM of ##a## and ##b## must have as factors simply ##a', b'## and ##g##, so ##l = a'b'g = a'b = a'gb/g = ab/g##
You can now see that the LCM is the product of ##a## and ##b##, divided by the GCD.
In our example:
##LCM(42, 15) = \frac{42 \times 15}{3} = 210##
Likes mfb
Thanks for sharing , i will keep this in my mind and maybe someday i will be able to use this advanced method . :nb)
But you don't need to know anything about prime factorizations to find the GCD; you can use Euclid's algorithm, which is very efficient.
You don't need prime factorizations to find GCDs. There is an efficient method not requiring any knowledge of prime numbers: Euclid's algorithm. This is the oldest algorithm still in standard use, dating back to Euclid's writings in the 3rd century BC, and it is very efficient.
\begin{align*}
\gcd(1989,867) & = \gcd(255,867) & & \text{since 255 is the remainder} \\
& & & \text{when 1989 is divided by 867} \\[10pt]
& = \gcd(255,102) & & \text{since 102 is the remainder} \\
& & & \text{when 867 is divided by 255} \\[10pt]
& = \gcd(51,102) & & \text{since 51 is the remainder} \\
& & & \text{when 255 is divided by 102} \\[10pt]
& = \gcd(51,0) & & \text{since 0 is the remainder} \\
& & & \text{when 102 is divided by 51} \\[10pt]
& = 51.
\end{align*}
Thus we have ##\dfrac{1989}{867} = \dfrac{51\times39}{51\times17} = \dfrac{39}{17}.##
Likes bagasme
This is wrong. Euclid's very efficient algorithm for finding GCDs does not require doing anything at all with prime numbers.
Yes, that has been mentioned in post 6 for example.
This thread is from 2017, by the way.
FAQ: A question about Greatest common factor (GCF) ?
1. What is the definition of Greatest Common Factor (GCF)?
The Greatest Common Factor (GCF) is the largest number that is a factor of two or more given numbers. In other words, it is the largest number that divides evenly into all of the given numbers without any remainders.
2. How do you find the GCF of two or more numbers?
To find the GCF of two or more numbers, you can use the prime factorization method. First, write out the prime factorization of each number. Then, identify the common prime factors and multiply them together to find the GCF.
3. What is the importance of finding the GCF?
Finding the GCF is important because it helps simplify fractions and expressions, and it is also useful in finding the lowest common denominator in fractions. It is also used in various mathematical operations, such as simplifying algebraic expressions and solving equations.
4. Can the GCF be greater than the smallest number in a given set of numbers?
Yes, the GCF can be greater than the smallest number in a given set of numbers. This is because the GCF is the largest number that is a factor of all the given numbers, so it is not limited by the smallest number in the set.
5. Is there a difference between GCF and LCM (Least Common Multiple)?
Yes, there is a difference between GCF and LCM. GCF is the largest number that is a factor of two or more numbers, while LCM is the smallest number that is a multiple of two or more numbers. However, they are related in that the product of the GCF and LCM of two numbers is equal to the product of the two numbers themselves.
12K
