A question about Heizenberg uncertainty.
  • Thread starter ndung200790
  • Tags
    Uncertainty
In summary, the conversation discusses the application of Heisenberg uncertainty principle in quantum field theory, specifically in relation to the momentum of a particle. It is noted that for particles with very large momentum, the uncertainty can be negligible. The conversation also touches on the difference between particles and quantum fields, where particles are excitations of fields and their values correspond to plane waves.
ndung200790
519
In some QFT books they say:If we consider momentum p of particle being very great,then the physics is at short scale.Then how can we apply Heizenberg uncertainty principle when the momentum p of particle having a certain value?What do they imply when they say that?
p is not an exact value, but for large p (as distribution, if you like) this can be negligible.
Consider a particle, confined in a space of 1cm: It has a corresponding minimal momentum uncertainty of ~0.1 meV. If the particle has a momentum of 1 MeV (10 billion times more than this uncertainty), you just don't care.
Is there any relation between great value p and great value of uncertainty in p?This(relation) explains why with the great p we have short scale physics as they say.
Great value of p is necessary for the great uncertainty in p.
Let's say, we have a particle with the well-known p, scuttering on the target (also well-known p).
Therefore there is a big uncertainty in x
But, after the scuttering, x may get well measured (xspace by affecting the lattice, xtime by energy dissipation), thus p should get big uncertainty.
In case of almost elastic scattering, xtime remain uncertain, and p uncertainty rely mostly on the angle uncertainty (ptime → E≈const ; px2+py2+pz2≈const)
By the way,are there any difference between particle and quantum of field?Do the value of field coincide with the wave function or not?
Particles are excitations of fields in quantum field theory, but I don't see the relation to the original question.
Is that correct if I say c[itex]^{+}[/itex]exp{p.x}/vacum> is the value of field of representation of a quantum of field.This quantum corresponds with a particle having the mean value of momentum equalling p.
I mean a well defined momentum of a quantum of field corresponds with uncertainty of momentum of a particle having that momentum.
I was wrong!Each ''quantum field value'' corresponds with a plane wave of particle!
FAQ: A question about Heizenberg uncertainty.
1. What is the Heisenberg uncertainty principle?
The Heisenberg uncertainty principle is a fundamental principle in quantum mechanics that states that it is impossible to know certain pairs of physical properties of a particle, such as its position and momentum, with absolute precision at the same time.
2. Who discovered the Heisenberg uncertainty principle?
The Heisenberg uncertainty principle was first proposed by German physicist Werner Heisenberg in 1927.
3. Why is the Heisenberg uncertainty principle important?
The Heisenberg uncertainty principle is important because it sets a limit on the precision with which we can measure certain properties of particles. It also highlights the probabilistic nature of quantum mechanics and the limitations of classical physics in accurately describing the behavior of particles at the subatomic level.
4. Can the Heisenberg uncertainty principle be violated?
No, the Heisenberg uncertainty principle is a fundamental principle of quantum mechanics and has been rigorously tested and confirmed through numerous experiments. Any apparent violation of the principle can be attributed to experimental error or limitations in measurement techniques.
5. How does the Heisenberg uncertainty principle affect our daily lives?
The Heisenberg uncertainty principle has little to no effect on our daily lives as it only applies to particles at the subatomic level. However, the principles of quantum mechanics that it is based on have led to the development of technologies such as transistors and lasers, which have greatly impacted our modern world.
