A question about MAN,DQDB and SMDS
  • Thread starter kidd
In summary, the question asks for an explanation of how data transmission is done in DQDB and how SMDS is used for a metropolitan area network (MAN). The conversation also mentions using existing utilities, such as Telephone Company, for laying cables in public land. The conversation asks for any expert to provide information or websites on the topic.
kidd
This is a question from my lecturer,i really cannot answer it because i dun understand about DQDB and SMDS,so wish anyone expert can tell me about it or give me some information for it.It is not much website can be found the information.If u know some website about this,please let me know,i will research it.Thank you all...
The question is:
A metropolitan areal network(MAN) is a network designed to extend over an entire city.Most organizations find that even if they could get permits to lay cables on public land,a better alternative is to use the services of existing utilities,such as Telephone Company.These services include:distributed queue dual bus(DQDB) and switched multimegabit data services(SMDS).Explain how the data transmission in DQDB is done and how SMDS is used for MAN.
Thanks a lot for help me.
Please don't multi-post.
Sure, I can provide some information on DQDB and SMDS for you.
Distributed Queue Dual Bus (DQDB) is a network technology used in MANs to provide high-speed data transmission over a shared medium. It uses a dual bus architecture, where two buses are used for data transmission in opposite directions. The data is divided into cells and each cell is given a priority level, which determines its position in the queue. The bus is shared by multiple nodes, and each node has a unique address. When a node wants to transmit data, it first checks if the bus is available. If it is, the node sends its data in the form of cells. If the bus is busy, the node waits until it is available. The cells are transmitted in a round-robin fashion, with higher priority cells being transmitted first. This ensures fair access to the bus and prevents one node from dominating the transmission.
Switched Multimegabit Data Services (SMDS) is a technology used in MANs to provide high-speed data transmission over a switched network. It uses a packet-switching technique, where data is divided into packets and each packet is given a destination address. The packets are then routed through the network to their destination. SMDS uses a connectionless approach, meaning that there is no pre-established connection between the sender and receiver. This allows for more efficient use of network resources and faster transmission speeds. SMDS also supports multiple classes of service, allowing for different levels of data transmission based on priority.
In a MAN, SMDS is used as a backbone network to interconnect different LANs and provide high-speed data transmission between them. It is typically used for data-intensive applications such as video conferencing, file sharing, and real-time data transfer. SMDS provides a cost-effective solution for MANs, as it utilizes existing infrastructure and allows for easy scalability.
I hope this helps to answer your question and provide some clarity on DQDB and SMDS. As for websites, some good resources for further reading on these topics include Cisco's website and IEEE publications. I would also recommend checking out some academic journals and books on networking for more in-depth information. Best of luck in your research!
FAQ: A question about MAN,DQDB and SMDS
What are MAN, DQDB, and SMDS?
MAN stands for Metropolitan Area Network, which is a computer network that connects multiple local area networks (LANs) within a city or metropolitan area. DQDB stands for Distributed Queue Dual Bus, which is a network access method used in MANs. SMDS stands for Switched Multimegabit Data Service, which is a packet-switched network used for high-speed data transmission over MANs.
What are the main differences between MAN, DQDB, and SMDS?
The main difference between MAN, DQDB, and SMDS is their purpose and technology. MAN is a type of network, DQDB is a network access method, and SMDS is a packet-switched network. MANs are used to connect LANs within a city or metropolitan area, while DQDB is a specific protocol used for accessing MANs. SMDS is a type of network used for high-speed data transmission over MANs.
What are the advantages of using DQDB and SMDS in MANs?
The main advantage of using DQDB and SMDS in MANs is their ability to handle high-speed data transmission. DQDB uses a dual bus architecture, which allows for increased bandwidth and faster data transfer. SMDS uses packet switching, which allows for more efficient use of bandwidth and faster data transmission compared to circuit-switched networks. Additionally, both DQDB and SMDS are scalable, making them suitable for growing MANs.
Are there any limitations of using DQDB and SMDS in MANs?
One limitation of using DQDB and SMDS in MANs is their dependency on physical infrastructure and distance limitations. DQDB requires a physical bus to be installed, which can be costly and may not be feasible in all areas. SMDS also has distance limitations, as the signal degrades over longer distances, which can affect the speed and reliability of data transmission.
How are MANs, DQDB, and SMDS relevant in modern networks?
Although MANs, DQDB, and SMDS were developed in the 1980s and 1990s, they are still relevant in modern networks. MANs are still used to connect LANs in cities and metropolitan areas, and DQDB and SMDS are still used in some MANs for high-speed data transmission. However, with the advancement of technology, newer and more efficient network technologies such as Ethernet and MPLS have become more commonly used in MANs.
