A question about quadratic residues
  • Thread starter yeland404
  • Tags
    Quadratic
In summary, The conversation discusses proving the solvability of the congruence X^2\equiv mod 2 and X^2\equiv mod 4, with specific conditions for the integer a. It is stated that X^2\equiv mod p has either no solution or two solutions, but only when p is an odd prime number. The conversation suggests checking these by hand to determine the number of solutions.
yeland404
23
I need to prove that a be a odd integer that congruence X^2[itex]\equiv[/itex]a mod 2
is always solvable with exactly one incongruent solution modulo 2.
this question is linked with (b) let a be an odd integer. Prove that the congruence X^2[itex]\equiv[/itex]a mod 4 is solvable iff a[itex]\equiv[/itex]1 mod 4. in this case ,prove that X^2[itex]\equiv[/itex]a mod 4solutions has exactly two incongruent
solutions modulo 4.
these two seem to link with each other. And the proposition I learn is X^2[itex]\equiv[/itex]a mod p has either no solution or two solutions, but p there is an odd prime number. HOw to apply to the queations above?
You should be able to just check these by hand. For example does x^2=2 (mod 4) have any solutions? Just plug in 0,1,2,3 for x and see what you get
Related to A question about quadratic residues
What are quadratic residues?
Quadratic residues are numbers that have a square root modulo a given number. In other words, they are numbers that, when raised to a certain power, leave a specific remainder when divided by a given number.
What are the properties of quadratic residues?
Quadratic residues have several important properties, including that they always have a square root modulo a given number, and that they are closed under multiplication and exponentiation.
How are quadratic residues related to quadratic congruences?
Quadratic residues and quadratic congruences are closely related, as quadratic residues are the solutions to quadratic congruences. In other words, quadratic residues are the numbers that satisfy a certain type of modular equation.
What is the significance of quadratic residues in number theory?
Quadratic residues have significant implications in number theory, particularly in the study of prime numbers and primality testing. They are also used in cryptography and coding theory.
How are quadratic residues used in real-world applications?
Quadratic residues have numerous real-world applications, such as in cryptography for secure communication and in error-correction coding for reliable data transmission. They are also used in various fields of engineering, such as signal processing and telecommunications.
