A question about Rectilinear motion
In summary, the question asks for the expression of the average speed of a particle traveling along a straight line with uniform acceleration, covering a distance of 3S in time intervals t1, t2, and t3. The options are (A) (S/t1) + (S/t2) + (S/t3), (B) (S/t1) - (S/t2) + (S/t3), (C) 3S / (t1 + t2 + t3), and (D) (S/t1) + (S/t2) - (S/t3). The correct options are B and C. To arrive at option B, one can express the average speeds in terms of
Priyadarshi Raj
Q:
If a particle moving along a straight line under uniform acceleration covers successive equal distances ( S each) in time intervals t1, t2 and t3 respectively, then the expression for average speed of particle in covering the given distance of 3S is:
Options:
[You may assume the particle is speeding up for the entire journey]
Here the correct answer are options B and C.
I cannot see how B is correct, although I easily got the option C.
Average speed = Total distance covered / Total time taken
Avg speed = (S + S + S) / (t1 + t2 +t3) = 3S / (t1+t2+t3)
This gives option C.
But I cannot get option B anyhow.
Good.
Hint: Each term in B is an average speed. Express those averages in terms of initial and final speed.
Okay then, I believe this is the way:
v2 will be average of v1 and v3
If the avg speeds are v1 = (S/t1) , v2 = (S/t2), v3 = (S/t3), then
Distance traveled during t2 is given by
S = v1t2 + 0.5at22 and also a = (v3 - v1)/t2 [using Newton's laws of motion]
∴ S = v1t2 + 0.5(v3 - v1)t2
⇒ (S/t2) = v1 + 0.5v3 - 0.5v1
⇒ 2(S/t2) = v1 + v3
⇒ 2(S/t2) = (S/t1) + (S/t3)
⇒ (S/t2) = (S/t1) - (S/t2) + (S/t3) = v2
⇒ vavg = v2 = (S/t1) - (S/t2) + (S/t3)
Am I correct?
Likes LoveBoy
I'm not sure I follow your reasoning.
Here's how I would look at it. For interval t1, let the initial and final speeds be v1 and v2. Express the average speed (S/t1) in terms of v1 and v2. Do the same for the other intervals and the total.
Thank you for helping me.
The problem is solved.
FAQ: A question about Rectilinear motion
What is rectilinear motion?
Rectilinear motion refers to the movement of an object in a straight line, without any changes in direction.
What are some examples of rectilinear motion?
Some examples of rectilinear motion include a car moving in a straight line on a highway, a ball rolling down a ramp, and a person walking in a straight line.
What is the difference between rectilinear motion and curvilinear motion?
The main difference between rectilinear motion and curvilinear motion is the path of the object. Rectilinear motion follows a straight line, while curvilinear motion follows a curved path.
What are the equations used to calculate rectilinear motion?
The equations used to calculate rectilinear motion include the equation of motion, which is used to determine an object's position, velocity, and acceleration, and the equations of motion with constant acceleration, which are used to calculate an object's displacement, velocity, and acceleration at a specific time.
How is rectilinear motion used in real-life applications?
Rectilinear motion is used in various real-life applications, such as in the design of roller coasters, cars, and airplanes. It is also used in sports, such as track and field events, where athletes run in a straight line. Moreover, rectilinear motion is used in physics experiments to study the motion of objects in a controlled environment.
9K
