B A question about rules of multiplication
Multiplication follows specific rules that prevent infinite distribution, unlike addition. When multiplying a number by a product, such as x times yz, the operation is defined to yield xyz rather than xyxz. Attempting to distribute multiplication in this way leads to an endless cycle of multiplication, which is not mathematically valid. Simple examples, like multiplying 3 by 7 times 8, illustrate that the result is consistently 3 times 7 times 8, equating to 168. Understanding these principles helps clarify the structure of multiplication in mathematics.
logicgate
TL;DR Summary
Why is it that x times yz equals xyz and not xyxz ?
This might sound like a stupid question but I am just wondering why is it that x times yz equals xyz and not xyxz ? Why don't we distribute multiplication in this case ?
Mathematics news on Phys.org
Think back to the simplest meaning or way to understand Multiplication. Maybe try a known numbers simple example.
Why is it that 3 times 7*8 equals 3*7*8 and is not 3*7*3*8 ?
You can first show 7+7+7+7+7+7+7+7 and find that this is 56.
(Same thing can be expressed as 8+8+8+8+8+8+8.)
You can now show 3*56 to be 56+56+56 (excuse me if I not stayed in the same form.) And what is this resulting number value? 168.
You can also choose to show that example graphically or visually.
That should help!
small edit done
Here is multiplication in real life:
  1. I lay down 8 blocks in a row.
  2. I want to multiply that by 7, so I copy step 1 six more times, making a total of 7 columns of 8-block rows.
  3. I want to multiply that by 3, so I copy step 1 and 2 twice more, making the 7x8 matrix a total of 3 times, stacked.
Why would I multiply by 3 again?
logicgate said:
TL;DR Summary: Why is it that x times yz equals xyz and not xyxz ?
Trying to "distribute" multiplication over multiplication would never stop. It is not like distributing multiplication over addition.
If x times yz = xyxz, then why stop there? Wouldn't x distribute again to give xyxxxz? And again to give xyxxxxxxxz? etc. And there should be similar distribution from the right by z. So now we could say that xyxxxxxxxz = xzyzxzxzxzxzxzxzxz, and that could be done again ad infinitum.
Likes symbolipoint and Lnewqban
Even if ##y = z = 1##?
Likes renormalize and phinds
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
