A question about the Dynamo Theory
In summary, Dave has read articles on Dynamo Theory and understands the basics of how it works. He is still looking for a more specific understanding of where the bootstrap field comes from and how it is generated.
zapnthund50
31
I'm studying Dynamo Theory, and have just a few questions. Today's theory says that currents in the molten outer core of the Earth give rise to magnetic fields. Now it would seem that the theory does not mean "molten iron currents", since together that is an electrically neutral substance, but rather "electrical currents", since it is known that a moving electrical charge generates a magnetic field. If this is true, then what induced the electrical currents in Earth's core? Am I grasping the main scientific concept behind field generation, or is there something else I'm missing? Thanks!
You have marked your thread with an "I" tag for undergraduate level education
what have you been reading in your research so far ? so we can gauge where you are at :smile:Dave
Likes jim mcnamara
Hi Dave,
My appologies, the thread was not meant to be marked undergraduate, but rather basic level. Thanks for pointing that out. Can you comment on the matter of currents?
Likes davenn
zapnthund50 said:
Hi Dave,
no problems :)
since I don't know what you have been reading ?
have you read this from Wiki ?
https://en.wikipedia.org/wiki/Dynamo_theory
or this
https://web.archive.org/web/20070221094040/http://setiathome.berkeley.edu/~pauld/etc/210BPaper.pdf
or this
http://www.phy6.org/earthmag/dynamos.htm
or this
http://farside.ph.utexas.edu/teaching/plasma/lectures/node70.htmlthat will keep you occupied for a while :smile:Dave
Likes zapnthund50
davenn said:
no problems :)
or this
or this
or this
Dave,
Thanks for all the links. I've thoroughly read each one, and I can say they proved a solid framework for beginning to understand Dynamo Theory. I had read the wiki article before, but the paper on the subject proved invaluable.
Based on what I've learned, the physics of DT can be simplified to the following: A conducting fluid circulates (convection, Coriolis effect) through an existing magnetic field. Moving this conductor (in our case, mostly molten iron) across magnetic lines of force forces a current to be generated. This current will have its own magnetic field. Of course the theory is much more complicated than that, but from what I can gather, this is the physics behind DT. (I think the wiki article was somewhat confusing, as it made no distinction between the physical current of molten iron, and the electrical current flowing through it.)
The only question I have left is, where does the original "bootstrap" field come from? Only one of the links ventured to guess, saying vaguely that weak magnetic fields are always present. All this just makes me want to study one of the many models that must have been made, but I have no idea where to find those. Anyway, thanks for your help.
Likes jim mcnamara
Related to A question about the Dynamo Theory
1. What is the Dynamo Theory?
The Dynamo Theory is a scientific explanation for the generation of Earth's magnetic field. It states that the movement of liquid iron and nickel in the Earth's outer core creates electric currents, which in turn generate the magnetic field.
2. How does the Dynamo Theory explain the Earth's magnetic field?
The Dynamo Theory states that the rotation of the Earth's core and convection currents caused by heat from the core's radioactive decay create an electrical current, which in turn generates the magnetic field.
3. Is the Dynamo Theory universally accepted?
While the Dynamo Theory is a widely accepted explanation for the Earth's magnetic field, it is still an area of ongoing research and study. Some scientists have proposed alternative theories for the origin of the magnetic field.
4. Are there any other examples of the Dynamo Theory in action?
Yes, the Dynamo Theory can also be applied to other planets, such as Jupiter and Saturn, which also have strong magnetic fields. It is also used to explain the magnetic fields of some stars and other celestial bodies.
5. How does the Dynamo Theory impact our daily lives?
The Earth's magnetic field plays a crucial role in protecting our planet from harmful solar radiation and cosmic rays. It also helps to guide animal migrations and is used in navigation systems. Understanding the Dynamo Theory helps us to better understand and protect our planet.
  • Earth Sciences
  • Classical Physics
  • DIY Projects
