- #36
Andrew Mason
- 7,780
- 475
The torque provided by gravity is tangential to the rotation of the centre of mass of the spinning wheel. Since the direction of "tangential" is constantly changing, the net change in angular momentum over a single revolution of 2π is zero IF there is no friction. But if there is even the slightest amount of friction, there is a net gravitational torque that will cause the gyroscope axis to tilt more (which will change the direction of the angular momentum spin vector which will lead to an increase the angular momentum precession vector to compensate). And eventually the spinning wheel/frame/top will touch the ground and stop.cmb said:A perfectly friction-free gyroscope that is fixed with a pivot along its axis does not so much 'resist' gravity as transfer any forces that act on it to the pivot.
AM
