A question about work and energy
In summary, the two observers will measure different velocities and different work done due to friction.
Prem1998
148
Consider two observers moving with respect to each other at a speed v along a straight line. They observer a block of mass m moving a distance x on a rough surface. The following quantity (or quantities) will be same as observed by the two observers:
(a) kinetic energy of the block at time t
(b) work done by friction
(c) total work done on the block
(d) acceleration of the block
This is only a thoughtful question so I don't think equations are needed. But if it is a rule, then:
KE=1/2mv^2 W= integration Fdx or FX when F is constant, etc.
I figured out that the answers should be b,c and d. It can't definitely be 'a' because the velocity of the block seen by both observers will be different. Now, since none of the observers are accelerating themselves, so they both will see the same acceleration of the block, so 'd' is correct. It is not a relativistic physics question, so 'm' will be the same for both. So, resultant force F=ma will also be same for both. And, distance moved, x is also same for both. So, total work done should be same, hence, 'c' is correct. Again, for both observers, the normal reaction on the block is same and coefficient of kinetic friction is also same. So, both observers will observe the same frictional force on the block and again the same distance moved 'x'. So, work done by friction is also same. Hence, b is correct.
But, in the answers section in the book, it was written that only 'd' is correct. Doesn't assuming that 'd' is correct lead to the conclusion that 'b' and 'd' are also correct?
Why do you think that distance moved would be same for both the observers ?
Why would the distance 'x' change? There is negligible length contraction here.
If the two observers are moving with respect to each other ,they cannot measure same displacement of the block .
Oh, I'm sorry. So, that eliminates 'b' and 'c' even if the resultant and frictional forces are same for both observers. Thanks. Isn't the question incomplete as it did not say in the book that v=/=0. I mean, v could be 0 leading to the same value of 'x'.
The question clearly states that the two observers are moving relative to each other
That rules out the possibility of them being at rest .
Instead if the question had only stated that there are two moving observers , then there could have been a possibility that the two observers were at rest with respect to each other measuring same displacement of the block .
FAQ: A question about work and energy
What is work and energy?
Work and energy are closely related concepts in physics. Work is defined as the amount of force applied to an object multiplied by the distance the object moves in the direction of the force. Energy is the ability to do work or cause change.
What is the difference between work and power?
While work is defined as the amount of force applied to an object multiplied by the distance the object moves, power is the rate at which work is done. It is the amount of work done per unit of time.
How are work and energy related?
Work and energy are related by the work-energy theorem, which states that the work done on an object is equal to the change in its kinetic energy. In other words, work is a means of transferring energy from one object to another.
What is the unit of measurement for work and energy?
The unit of measurement for work and energy is the joule (J). One joule is equal to the amount of work done when a force of one newton is applied to an object and it moves one meter in the direction of the force.
How is work and energy calculated?
Work is calculated by multiplying the force applied to an object by the distance it moves in the direction of the force. Energy is calculated by multiplying the force applied to an object by the distance it moves and adding any other forms of energy present, such as potential energy.
