A question involving work, power, etc.
For how long does the force act?In summary, a man with a mass of 85 kg is propelled out of a 2.5 meter long cannon by a force of 6000N in 0.35 seconds. The work done on the man by the cannon is 15,000 J, the average power exerted on the man is 42,857 W, and the man rises to a height determined by the equation mgyi+1/2mvi^2+work=1/2mvf^2+mgyf.
baileya
A man sits in a cannon and lights the fuse. A force of 6000N propels him out of the barrel (which is 2.5 meters long) in a time of .35 seconds. The man has a mass of 85 kg.
1. How much work is done on the man by the cannon? (ignore man's weight)
2. What is the average power exerted on the man?
3. How high above the cannon does he rise during his flight?
work= F(xf-xi)costheta
I didn't get far at all as the only examples in my notes weren't really like this question.
Well you know that work done = Force*distance
So in the cannon, what is the work done? (Hint: They gave you the force and the distance).
Remember that power is nothing but the work done per unit time (hint: they told you the time for which the force acts).
FAQ: A question involving work, power, etc.
1. What is work?
Work is defined as the application of force over a distance. It is a measure of the energy transferred when an object is moved by a force.
2. How is work calculated?
Work is calculated by multiplying the force applied to an object by the distance the object moves in the direction of the force. The formula for work is W = F x d, where W is work, F is force, and d is distance.
3. What is power?
Power is defined as the rate at which work is done, or the amount of work done per unit of time. It is a measure of how quickly energy is transferred.
4. How is power calculated?
Power is calculated by dividing the amount of work done by the time it takes to do the work. The formula for power is P = W/t, where P is power, W is work, and t is time.
5. What are some examples of work and power?
Examples of work include lifting an object, pushing a car, and climbing stairs. Examples of power include a light bulb converting electrical energy into light and heat, and a car's engine converting fuel into motion.
