A Question on Relativistic Mass (SR)
In summary, Rick calculates the difference between the sum of the masses of the objects when they are apart and the mass of the composite object they make after they stick together. He finds that the mass defect is the same no matter which frame of reference he uses.
ASmc2
28
Hello. I am independently studying modern physics. I have a basic special relativity question.
Consider a completely inelastic collision Of course, objects are moving at a constant velocity before and after the collision with respect to a stationary observer. Let's call him Rick. Suppose that Rick calculates the difference between the sum of the masses of the objects when they are apart and the mass of the composite object they make after they stick together. In his frame, he finds M. Here is the question. I know other inertial observers in different frames will measure different values of momentum and kinetic energy for the objects. I think, though, they will measure the same mass defect (M)? If not, why?
P.S. No force fields around.
If by "mass" you mean "rest mass", then since that is an invariant, all observers will calculate the same rest mass for each object involved, before and after the collision, so they will all calculate the same "mass defect".
Realistically, if you have a relativistic collision between two solid objects, you'll wind up with a hot ball of expanding plasma and perhaps the occasional exotic particle, depending on exactly how the collision was done.
However, you can visualize the two solid objects sticking together and colliding nicely, but you should remember that the collision product is going to be relativistically hot. It's not particularly plausible that any known form of matter would stay together in a nice package for you when it was that hot, but it doesn't break any physical laws so you can ask what happens if it does.
If you don't have any - or at least much - energy radiating from your relativistically hot final system, you can use the law of conservation of energy to say that the total energy of the final system is the same as the total energy of the initial system before the collision. I'll add in some notes as to what happens when you have radiated energy as well.
I will adopt the modern convention here of using "mass" to mean "invariant mass", so anywhere you see the word "mass", you can assume that I mean "invariant mass" and not something else.
If we call the invariant masses of the two particles before collision m1 and m2, the energies before the collision will be gamma1*m1 for particle 1 and gamma2*m2 for particle 2, where gamma = 1/sqrt(1-(v/c)^2). The two particles won't necessarily have equal speeds, so we need a velocity, and hence a gamma, for each of them.
So the energy and the invariant mass of the system at rest after the collision in its own frame will be m_tot = gamma1*m1+gamm2*m2.
If some energy Erad is radiated from the composite system after the collision, the total mass will be equal to m_tot = Erad = gamma1*m1+gamma2*m2 - Erad. If Erad is a function of time, m_tot will be a function of time. Erad will also in general depend on the observer, as well as time, due to issues involving the relativity of simultaneity
Note that in the rest frame of the composite particle, it's invariant mass will be equal to its energy, since the velocity of the composite particle is zero in its own frame of reference, and E = gamma * m.
In some other frame, the total energy of the final system will be the gamma factor * invariant mass.
In any frame, the invariant mass well be the same as long as Erad = 0. The invariant mass of a closed system is a constant which is independent of the observer doing the measuring. That's one of the reasons it's such a useful concept.
Sometimes people use "relativistic mass". It's mostly depreciated, though you'll find the occasional die-hard who insists that it isn't, and it's hardly worth arguing about. If you do run into the term, just remember that it's another name for energy.
If your confused about "which mass causes gravitation - invariant mass or energy", the most correct answer is neither one. Plugging either sort of mass into Newton's gravity law is not going to give relativistically correct answers. Answering the question of what causes gravity would drift from the equestion at hand and require a rather long post, so I won't do it here (besides, I'm out of time).
Related to A Question on Relativistic Mass (SR)
1. What is relativistic mass in the context of special relativity?
Relativistic mass is a concept in special relativity that describes the increase in an object's mass as it approaches the speed of light. It takes into account the effects of time dilation and length contraction on an object's mass.
2. How is relativistic mass different from rest mass?
Rest mass is the mass of an object when it is at rest, while relativistic mass takes into account the effects of motion on an object's mass. As an object's speed increases, its relativistic mass also increases, while its rest mass remains constant.
3. What is the formula for calculating relativistic mass?
The formula for calculating relativistic mass is m = m0/√(1-v2/c2), where m0 is the rest mass, v is the velocity, and c is the speed of light. This formula is also known as the Lorentz factor.
4. Can an object's relativistic mass exceed its rest mass?
Yes, as an object's speed approaches the speed of light, its relativistic mass will approach infinity. However, this does not mean that the object's rest mass has changed, as it will always remain constant.
5. How does relativistic mass affect an object's momentum?
Relativistic mass is directly related to an object's momentum. As an object's relativistic mass increases, so does its momentum. This is because momentum is equal to mass multiplied by velocity, and as an object's velocity increases, its relativistic mass also increases.
