A question on the commutativity of finite rotations
In summary: German language. Maybe I should write an English version of these lectures one day...But it's really not hard to work out what's going on in this chapter. The most important point is that in the canonical formalism you have a one-parameter group of canonical transformations, generated by the Hamiltonian (as in the time evolution) or by other conserved quantities. Then the Hamiltonian is a conserved quantity because its Poisson bracket with itself vanishes. This is a general feature of conserved quantities. They form an Abelian algebra. This is the case because of the Jacobi identity of Poisson brackets. In the case of the time evolution this is also a group, and its one-parameter subgroup generated by the Hamilton
FallenLeibniz
86
I was reading a section in my book discussing the commutativity of infinitesimal and finite rotations. In the book the authors try to set up a scenario to explain why finite rotations are not commutative. The following is an excerpt from the book regarding this language:
"The impossibility of describing a finite rotation by a vector results from the fact that such rotations do not commute, and therefore, in general, different results will be obtained depending on the order in which the roations are made. To illustrate this statement, consider the successive application of two finite rotations described by rotation matrices ##\lambda_1## and ##\lambda_2##. Let us associate the vectors ##\vec{A}## and ##\vec{B}## in a one-to-one manner with these rotations. The vector sum is ##\vec{C}=\vec{A}+\vec{B}##, which is equivalent to the matrix ##\lambda_3=\lambda_2\lambda_1##. But because vector addition is commutative, we also have ##\vec{C}=\vec{B}+\vec{A}##, with ##\lambda_4=\lambda_1\lambda_2##, But we know that matrix operations are not commutative, so that in general ##\lambda_3\neq\lambda_4##."
Now, to me, this language seems kind of murky so I had to think on this for awhile. Assume you have point P desginated by a vector ##\vec{r}## in a reference frame S. Applying the first rotation ##\lambda_1## can be represented by rotating P in S. Once the rotation is complete, the point is now at P'. If you consider vector ##\vec{A}## the vector that connects point P to P', it would be a representation of the rotation. Is this a physically plausible way to interpret the above explanation if you apply the same reasoning to the case of multiple rotations.
No idea... I get lost in that sort of talk too.
To see what they are on about, get an object like a book and rotate it two different ways and see if it ends up the same.
i.e. rotate 90deg about the vertical and then abouth a horizontal and see if it works out the same in the other order.
Work out how to describe that with vectors.
This approach is more useful than trying yo figure out what some author was trying to say.
The math behind this is that for a Lie group you can define "infinitesimal transformations", mapping it to a Lie algebra. Formally the Lie algebra is the tangent space at the unit element of the group. From the Lie algebra you come back to the group via the exponential mapping.
In quantum theory you encounter this mathematics from the very beginning. E.g., the translations in space form an Abelian group, and the infinitesimal generators are the momentum operators. Then there are the rotations, which form a non-abelian group. Here the infinitesimal generators are the angular-momentum operators, which span the Lie algebra su(2) of the rotation group. The commutators define the Lie bracket. The Lie product for the su(2) is thus given by the commutation relations of the angular-momentum operators
$$[J_j,J_k]=\mathrm{i} \sum_{l=1}^3 \epsilon_{jkl} J_l.$$
A finite rotation is then given by the operator-exponential function
$$D_{\vec{n}}(\varphi)=\exp(-\mathrm{i} \varphi \vec{n} \cdot \vec{J}).$$
Two rotations around two non-collinear axes ##\vec{n}_1## and ##\vec{n}_2## do not commute, although the infinitesimal rotations commute, because vector addition is always commutative.
Thank you for those responses.
@Simon Bridge: I did do the book turn thing to get an idea of what they are talking about and it is clear. Right now I am actually just trying to wrap my head around the author's language. Are you saying it is a better idea to just leave the language and take the main idea away that finite rotations don't commute (If I had the money to get a better book, I would. Marion and Thorton is all that I have at the moment).
@vanhees71: My mathematical knowledge doesn't go past a bit of Linear Algebra. I am working on gaining more, but for now your explanation is a bit beyond my grasp. I do get the basic idea from a few Googlings and from what I can gather from the searches, you're saying that the application of the commutators to the finite rotations (the non-Alebian group) is order dependent and not so for infinitesimal rotations (the Alebian group). Is that in the ballpark?
The point is that, roughly speaking, "infinitesimal" transformations commute to linear order of the parameters, while in general not at higher orders. For rotations, you can indeed make clear that for finite rotations two rotations around different axes do not commute. Simon gave a nice example.
If you have no money for a good book, I suggest you google for free manuscripts online. There are tons of good ones around about classical mechanics, e.g.,
http://ocw.mit.edu/courses/find-by-topic/#cat=science&subcat=physics&spec=classicalmechanics
Do you have any suggestions for one that is of a decent rigor or are the ones on MIT's OC of a decent rigor?
I am looking for something that presents the same material you would find in a text use for a two semester undergrad Mechanics class. I have a copy of Marion and Thorton's text which I used when I took the class (as for why I'm trying to "relearn", I'd rather not get into it). It's a good text with good rigor, but the author's explanations sometimes leave me to work out steps to try and see how they got from one conclusion to the next.
I don't know this specific book, but from the table of contents it looks very complete. Is there a chapter about Lie groups and Lie algebras? That would answer your questions. The most natural place is in the chapter about the Hamilton canonical formalism, where you have a direct realization of the Lie algebra of the space-time symmetries in terms of Poisson brackets. It's closely related to Noether's theorems, relating each conserved quantity with a one-parameter subgroup of the symmetry group of the dynamical system. For the space-time symmetries these are energy (time translations), momentum (spatial translations), angular momentum (rotations), and center of mass (energy) position (Galilei/Lorentz boosts). Unfortunately this point of view is rarely found in any texts. I've worked this out in my own lecture notes, but these are in German:
http://theory.gsi.de/~vanhees/faq/mech/mech.html
http://theory.gsi.de/~vanhees/faq-pdf/mech.pdf
The book actually doesn't get into the Hamiltonian formalism until chapter 6. This was actually the division in my courses between Mech 1 and Mech 2 (Mech 2 started with an introduction into Calculus of Variations then went into the Hamiltonian formalism). Nothing on Lie algebras.
Thank you for the notes too. :)
Related to A question on the commutativity of finite rotations
1. What is commutativity of finite rotations?
The commutativity of finite rotations refers to the property that the order in which rotations are performed does not affect the final result. In other words, if you rotate an object by a certain amount and then rotate it again by a different amount, the end result will be the same as if you had performed the rotations in the opposite order.
2. Why is commutativity important in rotations?
Commutativity is important in rotations because it allows for more efficient and accurate calculations. It also simplifies the understanding and application of rotation operations in various fields such as mathematics, physics, and computer graphics.
3. Can all rotations be considered commutative?
No, not all rotations are commutative. Only finite rotations, which involve rotating an object by a fixed angle around a specific axis, are commutative. Infinite rotations, such as continuously spinning an object, are not commutative as the order in which the rotations are performed does affect the final result.
4. What are some examples of commutative rotations?
Some examples of commutative rotations include rotating an object around a fixed point in three-dimensional space, rotating a Rubik's cube, or performing a sequence of dance moves that involve rotating your body by a certain angle each time.
5. How is the commutativity of finite rotations mathematically represented?
The commutativity of finite rotations is represented using the commutative property of multiplication. In mathematical notation, it can be written as R1 * R2 = R2 * R1, where R1 and R2 are rotation operations. This means that the result of rotating by R1 and then R2 is the same as rotating by R2 and then R1.
  • Linear and Abstract Algebra
