A question on work, power and energy
In summary, the conversation discusses an Atwood machine with masses of 2 kg and 3 kg and finding the work done by gravity during the fourth second after the system is released from rest. The equations used are mgh and distance traveled= 1/2(at^2) and the solution involves finding the acceleration and net mass of the system. The error is in using the distance traveled in 4 seconds instead of during the 4th second. The correct answer is 67J.
ritik.dutta3
The two blocks in an Atwood machine have masses 2 kg and 3 kg. Find the work done by gravity during the fourth second after the system is released from rest.
Work done by gravity= mgh
Both the masses will have the same acceleration 'a'. Let T be the tension in the string.
m1= 2 kg, m2= 3 kg, g= 10 m/s^2
T-m1g=m1a
therefore, T- 20= 2a
m2g- T= m2a
therefore, 30 - T= 3a
on solving both the equations, a= 2 m/s^2
distance traveled by the blocks would be 1/2(at^2). So, the heavier block would travel 16 m downwards and the lighter block 16 m upwards.
Net mass= 3-2= 1 kg
hence, the work done should be
W= mgh= 1 x 10 x 16 = 160J
but the answer is 67J.
where am I going wrong?
You have used distance traveled in 4 seconds .Whereas you need distance traveled during the 4th second i.e between 3rd and 4th sec.
Likes 1 person
Got it! Thanks! :D
Related to A question on work, power and energy
1. What is the difference between work, power, and energy?
Work, power, and energy are all related concepts in physics, but they have distinct definitions and units. Work is defined as the product of force and displacement, and its unit is joule (J). Power is the rate at which work is done, or the amount of work done per unit time, and its unit is watt (W). Energy is the capacity to do work, and its unit is also joule (J).
2. How do you calculate work?
Work can be calculated by multiplying the magnitude of the force applied to an object by the distance the object moves in the direction of the force. The formula for work is W = F x d, where W is work, F is force, and d is distance.
3. What is the relationship between work and energy?
Work and energy are closely related, as work is the transfer of energy from one form to another. When work is done on an object, energy is transferred to the object, and when work is done by an object, energy is transferred from the object. This relationship is described by the work-energy theorem, which states that the net work done on an object is equal to the change in its kinetic energy.
4. How is power related to work and energy?
Power is the rate at which work is done, or the amount of energy transferred per unit time. It is calculated by dividing the amount of work done by the time it takes to do the work. The formula for power is P = W/t, where P is power, W is work, and t is time.
5. Can you give an example of how work, power, and energy are related in everyday life?
One example of how work, power, and energy are related in everyday life is a person riding a bicycle. The person applies a force to the pedals (work), which causes the bike to move a certain distance (energy). The person's power is determined by how quickly they can pedal, as a higher power output will result in a faster speed and more work done in a shorter amount of time.
